Reply 20 of 22, by Scali
Nice!
Of course you'll need to upgrade to CGA at some point, so you can enjoy nice 8088 software like the Commander Keen CGA composite versions, 8088 Domination, 8088 MPH and such 😀
Nice!
wrote:Nice!
Right now I'm stuck with VGA, until I figure out how the RCA header on this video card works. I found the right pins, I think, but I can't get a signal out of it to save my life. Another part of the learning curve, I guess. Or, time to start looking for a CGA monitor so I can see if that plug on the card works.
Well, I've wasted way too much time trying to get it to work with the original monitor. I even tried using the red + hsync with a resistor to connect it to the VGA cable, and did get some messed up text on the screen (hsync way off, too high resolution)
I found a jumper to disable the ROM on my video card and tried to use it directly using the other switch settings, but that didn't work at all.
I think until I can afford to buy a video card with composite output (at ridiculous ebay prices) I'll probably just end up using an old VGA monitor. Oh well.
