First post, by appiah4
I got donated a bunch of CPUs. Along with a i386DX-20 with a soldered on pin that seems to be functional I got an i486 A80486DX-33 that is missing its S1 pin with nothing left in its place to solder a pin onto.
According to this spec sheet it is the A27 pin. I guess that means it's an address pin and is required to access RAM? I'm thinking this a critical pin, so the CPU wn't work without it, it is trash isn't it?
Reply 1 of 14, by Tiido
Lack of A27 means that you will get 2 mirrors of 256MB every 512MB block, which possibly works just fine as long as the CPU won't go into a PCI machine where it must access stuff in the last Gbyte due to various PCI things that normally live there. That pin needs to be pulled low with a resistor on motherboard end most likely though.
Reply 2 of 14, by appiah4
Umm.. So if I plug it into an ISA only or VLB motherboard it would work? 😲
Reply 3 of 14, by weldum
in theory it should work fine.
does soldering a new leg is not an option?
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 4 of 14, by appiah4
There is absolutely no pad whatsoever left to solder a leg onto..
Reply 5 of 14, by weldum
that's bad, because i've seen various processors fixed that way before, even pentium processors
Reply 6 of 14, by Tiido
You might have to solder a pulldown resistor on that pin on motherboard end but in theory it should indeed work.
Reply 7 of 14, by rasz_pl
can you make a picture? is there at least a stump in the spot?
there are conductive glues, would make really fragile connection, maybe glueing a small copper pad and sticking a pin into socket to form a friction joint when pressed could work
I havent seen ceramic 486 sliced in half, so no idea how the lead frame looks like internally, are those pins friction welded, glued?
Reply 8 of 14, by appiah4
Yeah sure, see the stump attached.
    868.63 KiB
Reply 10 of 14, by appiah4
treeman wrote:
that pad has to go somwhere, is it possible to dig in a little with a sharp knife to try find the end and add solder?
This is advice I heard from elsewhere too, just scrape it until you find the copper, then solder on the pin there..
I don't have the pin either, though 🤣
Reply 11 of 14, by treeman
I have a overdrive cpu that a pin fell off, I used a wire of similar thickness and length and soldered it to the pad. It will only go in a socket once and most likely fall off when you take it out, so I put it permanently in another socket/bracket like this
it works just like original now, so you need to dig down for the connection, solder some new pin from a similar length and fatness material and put it in a new socket
Reply 12 of 14, by SSTV2
Edge pads seem to be corroded and S17 pin looks like it's about to fall off. Perhaps there is a way of recreating pin connection by using conductive paint or glue, like rasz_pl stated, making it sort of "LGA" type of pad, but from the looks of it, it's probably not possible, as no metal wires are sticking out. I wonder what type of conductors were used to connect pins/pads with different layers in those ceramic CPUs.
Am5x86 133ADW guts:
1.69 MiB
1.55 MiB
1.78 MiB
Three layers can be seen, but no traces of metal.
Reply 13 of 14, by treeman
very very interesting, 3 layers I am guessing because 3 rows of pins so they are multilayer, looks magic no traces but the signal from the pins goes to the core. I wish I had a cpu to sacrifice because I am very curious now
Reply 14 of 14, by Tiido
There's no actual leadframe there from what I know, only sputtered gold. So there isn't anything to really solder onto. Conductive paint might be the only solution.
