Reply 29040 of 57094, by arncht
- Oldbie
wrote:wrote:Edit: Wait a minute, that's a Socket 7 board, not a Socket 8. Did you just post the wrong photo?
wrote:Sorry to disappoint you, but it isn't a PPro, rather a regular Pentium on a VX motherboard.
Ah no worries, for $20 all-in still not bad. Since it's Socket 7, do you guys think a DX4 100mhz would be faster than the CPU that's in there? I have a spare Am486DX4-100 kicking around
It looks a very common and late 430vx board with edo and sdram support and coast. It supports pentium cpus, with 60-66mhz fsb, and probably with mmx support. The battery in the rtc is empty, you have to replace it, anyway you can use just default setup settings.
