Reply 29080 of 57144, by HanJammer
This 5150 clone arrived today.
Siemens 8088-1 CPU, interesting Unitron motherboard with SIPP module socket and Acer chipset, CGA video and two 360kB floppies. Case has some shipping dammage (one corner is dented - fixable though) and HDD bay fillers are missing but other than that pretty nice conditions.
The attachment WP_20190612_12_18_13_Pro.jpg is no longer available
The attachment WP_20190612_12_18_24_Pro.jpg is no longer available
The attachment WP_20190612_12_24_16_Pro.jpg is no longer available
Reply 29081 of 57144, by blurks
ATI Graphics Ultra (0,5 MByte DRAM VGA, 1 MByte VRAM coprocessor)
Reply 29083 of 57144, by blurks
Nope, don't have a 5,25" floppy drive.
Reply 29084 of 57144, by Intel486dx33
I bought one of these inexpensive de-soldering guns from china.
It does not work. It does not heat up enough. Has anyone else had any luck with these inexpensive guns?
I just have a few motherboards to fix so I did not want to buy an expensive gun, but it looks like I might have to now.
Reply 29085 of 57144, by retropol
5,25 diskettes? wow, how old these gfx cards are?
Reply 29086 of 57144, by beastlike
Sorry to hear that! I just use a cheap pen-style soldering iron, doesn't have heat settings or anything. I have a gun that gets a little hotter but don't usually bother with it. By experimenting with the angle of the tip, coming in at like a 30° angle, getting more of the side of the tip into the solder joint, I've had better luck with my desoldering, and with a solder sucker, I'm able to "get in and get out" a lot faster
Reply 29087 of 57144, by cyclone3d
I looked at those before I bought my soldering station. Pretty sure there is even a teardown video of it on youtube. Decided it was a piece of trash and didn't buy it.
The desoldering gun I did end up buying is an antique and works very well.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 29088 of 57144, by Tiido
That soldering gun is for 230V, China uses USA plug for ungrounded things but it won't be 120V but 230V instead hence not heating up enough.
Reply 29089 of 57144, by luckybob
i got one of these: https://www.amazon.com/gp/product/B07542D82F/ … 0?ie=UTF8&psc=1
works perfectly, if you go slow and take your time. I recently desoldered 2x 387-pin cpu sockets and had zero issues.
Reply 29090 of 57144, by x0zm_
Along with a host of water cooling stuff, my two little retro-related pieces from China that I posted about earlier arrived today.
The third party charger but looks like a real IBM charger for the Thinkpad 600E I found:
The PS/2 Header for my P55T2P4
Reply 29091 of 57144, by Anonymous Coward
These would have sold new in 1991-1992, when most PCs still had 1.2mb drives. I got my 486 PC in late 1992, and it did not have a 5.25" drive, but strangely the OEM shipped the PC with the same Graphics Ultra and 5.25" driver disks, so I was unable to install the 256 colour windows driver until I was able to convince neighbour to help convert the disks to 3.5" format. Pretty annoying.
Reply 29092 of 57144, by Thermalwrong
That looks familiar 😁
I bought the same one, except for use in the UK. It's pretty useless even at 230 volts, the electromagnetic plunger makes the tool jerk so much that it's very difficult to keep it on the part you're trying to desolder. The soldering power of it is also quite weak. I get on a lot better with a high temperature soldering iron and a manual desoldering pump
Reply 29093 of 57144, by wirerogue
5 lbs of copper.
2 socket 604 coolers.
The attachment IMG_20190612_191943.jpg is no longer available
Reply 29095 of 57144, by HanJammer
I don't have this exact model (I have ZD-8915 desoldering station - inexpensive as well, works as charm even with post-RoHS stuff). I would try to fix this desoldering gun you have - for starters check the heating element (if it is not shorted/burned). If it's OK then check the temperature sensor.
Reply 29096 of 57144, by LuckyPiquel
Hi everyone, happy to finally have something to share in my first post here! Today the CD-R drive for my current project arrived. It is MITSUMI CR-2600TE from 1997, and I got it in a box with manuals etc.
According to the content list printed on the box, it seems that only some Disk Inspector Utility, IDE cable and initially attached blank CD's are missing. The drive is meant to be included in my dream machine from 1997, which I am currently building around Pentium 200 MMX.
Reply 29097 of 57144, by JonathonWyble
I think you have the same optical drive as me on one of my retro desktops. Although the optical drive I have has a rectangle button instead of an oval one like you have, but still.
1998 Pentium II build
Reply 29098 of 57144, by HanJammer
Bought this Mediavision PAS16P, Aztech Wavefront and Vibra16 (with OPL3).
Also this Gainward S3 Virge DX and Miro S3 Trio 64V+.
Also Magitronic A-B245... seller claimed it's working just no keyboard socket, but when I installed RAM (tested both the SIPPs and DIPs) it won't work - stops on post code 19 (memory refresh test). There is some corrosion under DIP40 KBC socket. I will test it with Landmark Diag ROM and I will decide if I will return it. I bought it partially because of IIT NPU and it would be a shame, but on the other hand I paid a bit too much too:/
Also this 286A-16 Rev. 2.0. with integrated serial/parallel/gameport/FDD/HDD controllers. This one works OK, but obviously need new Dallas chip... Also one of the memory modules seems shot.
Reply 29099 of 57144, by Windows9566
Got myself a full tower AT/ATX case from ebay with a turbo button and MHz display.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
