First post, by Frednoeyes
Greetings All! I've been trying to get Jane's Fighters Anthology working on Windows 7, but it's been uncooperative. Running it in regular Win 95 compatibility mode makes the menus laggy and causes the cutscenes to crash. Trying it with dgVoodoo 2 caused the game to lock up hard. Any suggestions?
Reply 1 of 8, by mrpenguinb
Disable visual themes if you can. Also disable desktop composition and transparency, instead of using Win 98 compatibility mode.
Reply 2 of 8, by Frednoeyes
Alas, I'm afraid that I already had all of that stuff disabled already, so not my solution.
Reply 3 of 8, by filipetolhuizen
Try my custom fix. You'll need MS Application Compatibility Toolkit to use it.
The attachment fa.rar is no longer available
Reply 4 of 8, by Carrera
What does this fix do exactly?
Reply 5 of 8, by Frednoeyes
Not really sure if the fix isn't working for me, or if I'm too stupid to implement it correctly, no luck still either way.
Running FA in anything other than Win 95\98 Compatibility mode causes a crash.
Thanks though.
Reply 7 of 8, by filipetolhuizen
Basically it sets thread affinity to 1 core, avoiding crashes, while still keeping the mouse movement smooth (jerkyness is a side effect of single thread affinity). It also sets the desktop resolution to 640x480x8 to avoid crashes between missions. I may have set some useless compatibility flags as well, but since it ran stable as a rock, I decided not to remove anything.
Thanks though.
You need Microsoft Application Compatibility Toolkit to be able to use the fix. Just open the fix with MS ACT and install it. Anyway, the official patch 1.02F is highly recommended. And for the colours to show correclty, either Directdraw Compatibility Tool or a batch file to stop explorer.exe while in the game is needed.
Reply 8 of 8, by Deffnator
Jane's FA with the official patch and nocd by Jfkpeterson forums doesnt work well with Dgvoodoo2, it suffers from black screen stuttering bugs
ATF on the Other hand, has no problems with it
