First post, by GabrielKnight123
Im trying to make a DVD that will have all the files needed to play Gabriel Knight 2 from its 6 CD's I know there is a program that will do this but when I used it it only makes the Windows install and not the Dos install so I would like to make the DVD work as if all the CD's are on it but each CD uses a single "Resource.AUD" file and "Resource.SFX" file and not a numbering system for each CD. If I use a command prompt and use:
copy /b C:\Resource1.AUD + C:\Resource2.AUD + C:\Resource3.AUD + C:\Resource.AUD will this copy each AUD file into one? I am renaming each Resource file from the CD it came from hence the numbering which isnt actually there.
