First post, by cyclone3d
Working on testing / putting together a system with an ASUS P5A-B motherboard.
I decided to make a post to consolidate information since I was having trouble finding some specific info I was looking for - mainly the BIOS revision history.
Most of this info will carry over to the P5A as well.
Latest BIOS:
1011bn005.zip
Flash utility - the version that ASUS says to download doesn't work - gives an "unknown flash" error and will not flash, it requires a newer version:
aflash.zip
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 14, by cyclone3d
P5A-B BIOS revision information:
Latest Beta BIOS revision source: http://www.k6plus.com/phpBB3/viewtopic.php?t=1105#p9014
1011bn005.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1011beta 05/13/2002
1. Fixed PME not enabled for some cards.
2. Remove Set off APM Mode 1.0 checking, fix Win 2000 APM mode can't shut down.
3. Fixed P5A/P5A-B when shutdown in Windows XP cannot turn off power.
Older BIOS revisions source: http://www.elhvb.com/mobokive/archive/asus/so … p5a-b/index.txt
ab5i1010.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1010 05/31/2000
ab5n1010.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1010 05/31/2000
1. Support IDE HDD larger than 32GB.
ab5i1008.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1008 10/25/1999
ab5n1008.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1008 10/25/1999
1. AGP Turbo mode default disabled.
2. Added patch code for nVidia Riva TNT2.
3. DMI revised for max CPU speed, max DRAM size & L2 cache size entries.
ab5i107a.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1007.A 09/14/1999
ab5n107a.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1007.A 09/14/1999
1.Fix for AMD K6-2 500MHz processor speed detection error.
2.Add Y2K patch.
3.IRQ 12 released if PS/2 Mouse not installed.
4.Fix for Cyrix MII-366 detection error.
ab5i1007.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1007. 05/17/1999
ab5n1007.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1007. 05/17/1999
1.Fix for AMD K6-3 475MHz processor speed detection error.
2.Added K6 Write Allocate control item.
3.Fix for ATI Rage128GL/VR shutdown hang problem when using K6-3.
4.Added patch for ATI Rage128GL/VR.
ab5i1006.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1006. 03/22/1999
ab5n1006.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1006. 03/22/1999
1. Fix for USB falied in DOS mode with 1006.004 BIOS.
2. Fix for Windows 200 shutdown failure with 1006.004 BIOS.
3. Added support for 450MHz K6-2 & K6-3 with Vcore = 2.4V.
4.Fix for ATI Rage128GL driver installation failure.
5. Added support for Modem Power Up in ACPI mode.
6. Added support for Wake On Lan in ACPI mode.
7. Fix for NT5.0/W2000 installation failure.
8. Fix for NT5.0/W2000 HCT 8.0 test failures.
9. Fix for system reboot at SCSI init with K6 & USB.
10. Changed name for AMD-K6-3 to AMD-K6-III.
11. Fix for flash utility failure with USB keyboard attached.
12. Added ATI RagePro Patch for P5A-B WOA.
AGP DPLL counter += 7
ab5i1005.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1005. 01/15/1999
ab5n1005.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1005. 01/15/1999
1.Added ATI RagePro Patch for P5A-B. AGP DPLL counter += 7
2.Added Rise mP6 recognition.
3.Added "CDROM,A,C" boot sequence.
4.Added AMD-K6-2 366/380 support.
5.Parity check bit enabled for supporting some Creative audio cards which use NMI for SB16 emulation.
6.Added IR PnP BIOS node report if IR enabled
ab5i1004.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1004. 10/21/1998
ab5n1004.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1004. 10/21/1998
1. Fix for Matrox Mystigue PCI card crashed after VGA firmware was upgraded.
2. Fix for HCT 8.0 PCI test error.
3. Added patch for Riva TNT.
4. Fix for USB_IRQ_ITEM no function.
5. Fix for system reboot with the combination of AMD K6-2 & USB Keyboard.
6. Fixed modem wakeup failed under Win98 (ACPI mode).
7. Disable Ring Wakeup under Win95/Win98 (APM mode) if it's Setup disabled.
8. Fix system hang at POST 0dh when Winfast S800 VGA card is plugged in.
9. Fix for NT 5.0 when working in ACPI mode got shutdown when Space bar is pressed.
ab5i1003.zip P5A-B M/B (ALi 1541/1543C), BIOS ver. 1003. 08/28/1998
ab5n1003.zip P5A-B M/B WO/Audio (ALi 1541/1543C), BIOS ver. 1003. 08/28/1998
1. Add AGP patch for 3D Labs Permedia2, Trident 3DImage 9850, Nvidia Riva 128.
2. Fix the system can't boot from some model of LS-120.
3. Fix ESCD updated unexpectedly.
YMF7x4 Guide
Reply 2 of 14, by cyclone3d
P5A BIOS revision information:
Source: http://www.elhvb.com/mobokive/archive/asus/so … i/p5a/index.txt
al5i107a.zip P5A M/B (ALi 1541/1543C), BIOS ver. 1007.A 07/16/1999
1. Fix for AMD K6-2 500MHz processor speed detection error.
2. Add Y2K patch.
3. IRQ 12 relesed if PS/2 Mouse not installed.
4. Fix for Cyrix MII-366 detection error.
al5i1007.zip P5A M/B (ALi 1541/1543C), BIOS ver. 1007. 04/30/1999
1. Fix for AMD K6-3 475MHz processor speed detection error.
2. Added K6 Write Allocate control item.
3. Fix for ATI Rage128GL/VR shutdown hang problem when using K6-3.
4. Added patch for ATI Rage128GL/VR.
al5i1006.zip P5A M/B (ALi 1541/1543C), BIOS ver. 1006. 03/24/1999
4. Fix for ATI Rage128GL driver installation failure.
13. AGP DPLL counter += 7
al5i1005.zip P5A M/B (ALi 1541/1543C), BIOS ver. 1005. 01/15/1999
al5i1004.zip P5A M/B (ALi 1541/1543C), BIOS ver. 1004. 10/21/1998
al5i1003.zip P5A M/B (ALi 1541/1543C), BIOS ver. 1003. 08/28/1998
YMF7x4 Guide
Reply 3 of 14, by cyclone3d
Experiences with K6-2, K6-2+, and K6-3+ CPUs , motherboard cache and bus speed:
K6-2 - works fine at 120Mhz fsb with motherboard cache enabled
K6-2+ - must disable motherboard cache for 120Mhz bus speed. Seems to work with motherboard cache enabled up to 110Mhz bus speed.
K6-3+ - must disable motherboard cache for 120Mhz bus speed. Seems to work with motherboard cache enable up to 110Mhz bus speed. May not be fully stable even with motherboard cache disabled. Will do more testing later.. but there seems to be some sort of timing issue with the K6-3+ where there isn't with the K6-2+. Tried 2 different K6-3+ 450Mhz CPUs with the same exact results.
Results were exactly the same between 2 version 1.04 motherboards even though they have different branded motherboard cache.
The version 1.03 motherboard I have seems to not handle the higher bus speeds quite as well.
The K6-2+ 550Mhz was hitting 660Mhz (120x5.5 or 110x6) easily.
Both K6-3+ 450Mhz CPUs seemed to have some timing issue with the motherboards and going over 630Mhz. Will be testing with some Via based motherboards to see if I can clock them any higher.
YMF7x4 Guide
Reply 6 of 14, by 1541
Here's a similar approach on the P5A using a K6-III+ with various speeds:
https://www.creopard.de/2018/02/Retro-PC-Spie … nter-MS-DOS.htm
(english translation: https://translate.google.com/translate?hl=de& … nter-MS-DOS.htm)
and of course:
https://www.philscomputerlab.com/k6-2-2-3-resources.html
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 7 of 14, by Gopher666
I bumping this up to ask for advice if this is a good board to combine with a Voodoo3 3000 AGP 16MB card and K6-III CPU?
There was a similar thread: Asus P5A very slow AGP / Video cards
- ASUS P5A - ATX, 5 PCI, 3 ISA, AGP, 3 SDRAM, supports FSB up to 120MHz, ALi Aladdin V based, supports voltages from 2.0 to 3.5V in 0.1V increments - best ALi Aladdin V motherboard by far. Has minor AGP issues with some video cards. The ALi chipset can perform better then the MVP3 chipset when it comes to memory performance, but these boards can be fragile so handle with care and don't use for testing parts or benchmarking.
However as it's been said on the thread Voodoos don't have an issue because they don't take advantage of the AGP port just use the PCI instructions.
Also according to this comparison this board is doing kinda good:
file.php?id=32949&mode=view
I just don't want to build an unstable system which needs to be rebooted in between every 2 game starts or in every hour, keep bsoding or doesn't even start up sometimes when it does not feel like it 😀
So pls if you this board share your experience.
Reply 8 of 14, by Sphere478
What bios settings are you guys using? I’m having stability issues can’t pass a 3dmark
Gopher666 wrote on 2021-01-25, 17:18:
I bumping this up to ask for advice if this is a good board to combine with a Voodoo3 3000 AGP 16MB card and K6-III CPU? […]
This is by far the fastest I’ve ever seen my k6-III+ 550 ever perform this board is awesome, but I’m having stability issues.
Sphere's PCB projects.
Reply 9 of 14, by bloodem
What are your full system specs?
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 10 of 14, by Sphere478
bloodem wrote on 2021-12-25, 13:11:
K6 3+ 550
640mb cl2 pc133
Radeon 9800 pro
Audigy 2 zs
Promise tx4 sata II 300
Windows XP sp3
Asus p5a 1.4
Latest 1011 005? Bios? I forget does that sound right?
Reply 11 of 14, by bloodem
Any reason why you're running Windows XP (and especially SP3, which is known to come with a lot of bloat)? Even Windows XP SP1 is well above the capabilities of a SS7 platform.
Two other red flags that I see are the Promise SATA II controller and the Radeon 9800 PRO. I'm pretty sure ATI never thought of testing these cards (and their drivers) on such a weak and problematic platform. 😀
Your BIOS version seems right.
To make sure that things are stable under 'normal' circumstances, I would first test with the following configuration and if stable, then go from there (i.e. make changes until you find the source of the instability):
K6-3+ 550
128 MB RAM
a cheap GeForce 2 MX/MX400 (driver 7.76) - if it's unstable in 3D apps, disable AGP 2X with the Ali AGP tool.
default onboard IDE controller
Windows 98 SE (clean, no service packs)
As an example, I have two Asus P5A rev 1.04 configurations and they're both 100% stable:
CONFIG 1 (my fastest SS7 platform):
AMD K6-3+ 400 MHz OC @ 633 MHz (FSB115 x 5.5)
128 MB RAM (more RAM works fine, but will come with a 5 - 10% performance penalty, depending on the game)
VGA: GeForce 2 GTS (driver version 7.76 / AGP 2X disabled)
OS: Windows 98 SE (no service packs)
CONFIG 2 (not as fast as the first, but more compatible):
AMD K6-2+ 550 MHz OC @ 616 MHz (FSB112 x 5.5)
128 MB RAM
VGA: Voodoo 3 3000 AGP (Frame Buffer Size: ALL / Write allocation: Enabled without hole)
Reply 12 of 14, by Sphere478
bloodem wrote on 2021-12-25, 17:18:
Any reason why you're running Windows XP (and especially SP3, which is known to come with a lot of bloat)? Even Windows XP SP1 i […]
K6-3+ 550
128 MB RAM
128 MB RAM
I’m starting to suspect the 9800 pro. More testing required.
I can try sp1. I usually just go through and trim the bloat back 🤣. I’ve come to the conclusion that XP is going to be the OS for this build after having issues with software I’m using on other versions
Reply 13 of 14, by Sphere478
Ooo!! the infamous hidden settings. Finally found them!
Dudes, it goes to 150mhz?!? Wtf?! Lol
Ummm 150 x 6x is 900!
Someone emerse this in ln2 and grab that cpu-z verification!
Reply 14 of 14, by atlantisworld
K6-3+ 550
128 MB RAM
128 MB RAM
I have this config:
K6-2+ 570 @600 (100 x6)
128MB 100 (i have two modules more 128mb 133 without use)
P5A V1.03 with latest bios b5
V3 3000 agp (Frame Buffer Size: ALL / Write allocation: Enabled without hole)
Win98SE
Can you show the p5a bios parameters of your config 2 or
what setting to change in bios to optimize this configuration?
Thanks!
