First post, by kikendo
- Member
I recently found an ES1370 and I was excited as I saw it recommended as a good option for PCI audio compatible with DOS, and it's absolute trash!
I mean, the sample reproduction is ok, but have you heard the MIDI implementation? No matter what wavetable set I use, all music sounds out of tune.
Why is it recommended? An SB Live! with its SB16 emulator sounds a million times better than this and works with most DOS stuff.
