Reply 12180 of 27491, by Jed118
Got an ATX power supply and AT converter harness, and...
(Optimus SA, Poland REPRESENT!)
My next video will be about how to convert an AT on-off push style switch into an ATX compatible momentary switch. About time I made a new video, vacations be damned.
LIFTOFF!
Takes both 30 pin and 72 pin, VLB video card and motherboard works, pleasant surprise (I was 90% sure motherboard would work, 25% video card would)
850 Mb drive is formatting now, just need to source a VLB I/O card, as for now it's using an (Optimus S.A. stamped) 16 bit I/O controller.
This is all after my other retro activity, repainting the door frames and drip rails on my 87 Hyundai. 3 hours to mask, 15 mins to paint. Great!
What's for sale? my eBay!
Reply 12181 of 27491, by Jed118
GigAHerZ wrote:
There you go 😀
https://imgur.com/a/7IHWZJu
With all that effort, why not shoot some eggshell paint at it?
Reply 12182 of 27491, by mothergoose729
Overclocking my 2x256mb DDR memory kit in my socket 478 machines. These no name hynix chips have treated me really well so far. I have got them stable at 500mhz with CAS 2.5 timings. Currently working down the sub timings and various memory latency sub options to minimize latency.
Even though all of my modern machines are orders of magnitude faster in just about every way, it is still quite satisfying to squeeze out just every drop of performance from my retro machines 🤣 Next on my agenda... see if I can undervolt this hot northwood processor to tame the heat!
Reply 12183 of 27491, by Caluser2000
Bit of old fashion trolling. Man it feels goood.
Reply 12184 of 27491, by Mister Xiado
Arguing that glass is an amorphous solid with viscosity higher than that of pitch, using photos of antique glass as evidence? That was always a good troll, before the term was redefined to mean "someone disagreed with me in some way".
I'm just messing around with a few more icons, for lack of anything else to do.
51.49 KiB
Reply 12185 of 27491, by Intel486dx33
I made some back plate turbo switches and they work great.
I just drilled a hole in these back plate covers and attached the switches.
Later I modified some case power switch wires and screwed them into the turbo switch.
I finished them off with a little solder so they would not come loose.
You can buy these switches and case power switch wires from eBay.
Cost about $1 each to make if you purchase lots of 10
With the Turbo switch enabled I can cut my CPU speed in half.
So 133mhz becomes 66mhz.
And with "Setmul" utility you can reduce that even more. Disabling CPU L1 cache will reduce a 5x86-133mhz CPU to a 386sx-25mhz.
This is great for playing old DOS games that require a slow CPU like "Wing Commander 1"
Reply 12186 of 27491, by Jed118
I tried to install PC DOS 6.1 (with compression) onto my new 486 build.
In the past, I have tried these disks with 386 machines, and they gave me an error that it requires an 80486 CPU to continue setup.
So, this time I have a 486 CPU and it gives me this error:
I'm installing DOS though, why would it be making prerequisites for Windows? I think I got these diskettes in the mid 90s, and actually now, I am not entirely sure if I've ever installed them on a PC of any kind.
What the hell kind of computer are these diskettes for? I'm running low on diskettes, I'm considering formatting these and using them for unlabelled purposes.
(or, how do I hack the .ini file to make it work here?)
Reply 12187 of 27491, by Caluser2000
Just put the disks in a system that has a 3.5" drive and see whats on them in Dos or any other OS. Dos 6.1 installs on any x86 arch. from 8086 up. https://www-01.ibm.com/common/ssi/ShowDoc.wss … quest_locale=en You can recreate the disks as PC Dos 6.1 by downloading the images from winworldpc.com and creating the disks using RawWrite for windows. 3.5" disks are readily available at Amazon.
Reply 12188 of 27491, by Jed118
Fantastic.
Let's up the ante - I'll send you these diskettes, originals, without me making any backup copies, and you film a video of yourself installing the OS onto a computer. Hell, I'll even host it on my extremely popular channel.
PM me, let's get something going.
Reply 12189 of 27491, by Caluser2000
Did you actually read my post? You have problem. I provided a very simple solution. It's pretty damn obvious at least disk 1 has been altered. You'll most like find if you veiw it in any old file manger you may find a readme.txt or similar telling you what the altered disk/s are for. The text file I posted shows the IBM Dos 6.1 can be installed on 8086s up. If you bother to read it shows there were some nice features on that version of Dos. Around that time IBM and MS parted ways as far as Dos goes with MS theoretically(marketing wise anyway) dropping Dos when Win95. IBM provided PC Dos right up to 2000 and all PC Dos versions ran on 8086s up.
To quote IBM:
Hardware Requirements: PC DOS 2000 operates on Intel (TM)-based or Intel-compatible PCs (808x, 286, 386, 486, and Pentium (TM) processors). The minimum system memory required for PC DOS 2000 installation is 512 KB. Check with the hardware manufacturer to determine if your hardware is Year 2000 ready.
PC Dos 2000 when loaded took just amount of conventional memory as PC Dos 3.3 did.
Reply 12191 of 27491, by mothergoose729
wiretap wrote:
It was a nice day, so I cut a hole in my Voodoo 5 Shuttle case to add a mesh window, added a handle, and painted it. […]
This is a work of art. Have you done a build showcase for this anywhere? I would love to know more about it.
Reply 12192 of 27491, by Caluser2000
Jed118 wrote:
🤣 how can I do that on a fresh system install?
Now you are being silly. To repeat the above:
You have problem. I provided a very simple solution. It's pretty damn obvious at least disk 1 has been altered. You'll most like find if you veiw it in any old file manger you may find a readme.txt or similar telling you what the altered disk/s are for. The text file I posted shows the IBM Dos 6.1 can be installed on 8086s up. If you bother to read it shows there were some nice features on that version of Dos. Around that time IBM and MS parted ways as for as Dos goes with MS theoretically(marketing wise anyway) dropping Dos when Win95. IBM provided PC Dos right up to 2000 and all PC Dos versions ran on 8086s up.
To quote IBM:
Reply 12193 of 27491, by Caluser2000
1.2 MiB
Just getting some files off my old OS/2 v4 install. Looks pretty funky in 640 x 480 16 colour mode on my 17" LCD. Oh look! A file manager.
Reply 12195 of 27491, by bjwil1991
DOSPhone.
Can someone please make a smartphone that only has DOS and not Android or iOS?
Yesterday, my brother and I went to a salvage yard in my city to get replacement headlamp assemblies for my dad's car as the headlamps on there were hazy and the right turn signal stopped working (electrical issue). I found a pair of them in perfect shape at the salvage yard, and $53.99 later, I installed them in my dad's car (fixed the right headlight low beam area as the cover that goes over the headlight was loose and I eventually got it on with a pair of needle nose pliers with little to no wiggle room and my screwdriver with an extension (ratchet socket set)). The bulbs that are in there work without issues and he now has a right turn signal (I had to use my arm as a turn signal for a long time) and my dad was happy to have better headlights for his car.
I also did some headlight restoration today on my mom's 2007 Chevy Uplander as they were a bit hazy on top, but, looked good at the bottom and did the same thing with my 2001 Oldsmobile Intrigue's tail lamp assemblies and 3rd brake light as they were a teeny tiny bit hazy and they look like new. My headlamp assemblies are original and they aren't even yellowed or hazy.
Reply 12196 of 27491, by PcBytes
Tried to repair a Chicony/AEI TK-8498F Socket 3 motherboard.
Sadly had no success - installed some Paradigm PDM41256 cache chips (9 of them total) (though, is it a requirement to use UMC chips? Just want to know so I can track down some chips if needed) and replaced a few capacitors that were probably dry since god knows how long ago, but I am getting no POST nor any beeps.
Reply 12197 of 27491, by wiretap
I have a mini-log here: https://smallformfactor.net/forum/threads/3df … -shuttle.11044/
My Github
Circuit Board Repair Manuals
Reply 12198 of 27491, by Mister Xiado
Investigated making OS/2 icons, but at that rate, I may as well go back to making skins for Nintendo DS flash cards for all the good it would do. That, or paint the underside of public trash cans.
Pulled the clock capacitor from a 1.0 Xbox, drastically underlining my need for a desoldering gun to do this kind of work. I spent almost 20 minutes trying to wick the solder out of the through-hole before giving up.
Reply 12199 of 27491, by PC Hoarder Patrol
Been cycling my stored socket 754 kit thru some visual inspections and benchmark runs just to check for signs of degradation - thankfully nothing obvious so back to storage.
1.35 MiB
ASRock K8N68PV-GLAN (Nvidia 7050/630A), Abit KV-85 V2.0 (VIA K8M800 ), Foxconn 760GXK8MC (SiS 760GX/964 )
1.38 MiB
Biostar iDEQ N1 sff (NVIDIA 6100/410)
1.53 MiB
