First post, by french_whore
I'm installing system shock in DOSBox, and when I get to the part where I choose installation directory, I choose c:\sshock (default) and it says I can't install to that directory. huh?
Reply 1 of 8, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Just one off-topic comment: could not you choose a better (less-offensive) name?
If I was a VOGON admin I would delete it on the spot. You are lucky that I am not.
Mirek
Reply 2 of 8, by eL_PuSHeR
Please write down here all the exact commands you used to install SS.
They should be something like this...
mount c c:\
mount d d:\ -t cdrom
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 8, by french_whore
mount C "C:\apps\dosboxapps"
mount H "H:\" -t cdrom -ioctl
H:
cd inst
initial
(initial is the name of the installer)
Reply 4 of 8, by Dominus
DOSBox Moderator
shouldn't the installer be in the root of the CD? Sometimes it is not wise to start the installer directly but start the install.bat or setup.bat or similar in the root. I encountered a similar game once and wrote it down here but forgot which it was...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 8, by french_whore
Ok, this is a bit weird. In total, there appear to be 4 installers on the CD:
H:\install.exe
H:\origin.bat
H:\doc32\inst32.exe
H:\inst\initial.exe
install.exe and inst32.exe don't work. When I try to launch either one in dosbox, it says "this program requires windows", but when I try to run it in windows, it gives me a "wrong number of params" message.
origin.bat and initial.exe both seem to work fine in windows, but I need them to run in dosbox for the SB16 sound emulation. When I try to start origin.bat in dosbox, I get 16 lines of errors. And I've already told you what happens when I run initial.exe in dosbox.
Reply 6 of 8, by DosFreak
I was getting the same error as above until I simply moved the files in the directory that the installer was looking for. I could then save the sound settings which I couldn't do before since the installer kept on telling me that the game was not installed. (Wasn't an original copy)
Make your games work offline
Reply 7 of 8, by french_whore
(this is in DOSBox 0.61, by the way. I should've mentioned that earlier)
Reply 8 of 8, by french_whore
Figured out my problem. I have both v61 and v63 installed, and I was mounting C to the same directory in both of them. Didn't realize until now that you couldn't do that.
