Reply 12240 of 30585, by Jed118
I found a virus on a diskette I installed a game onto a client from.
Naturally, 400+ diskettes were scanned today.
Then I organized them, why not, from this lot:
to this lot:
I took the opportunity to format a handful of diskettes and put them in the "to use" pile while I was at it.
Certified <2006 virus free!
What's for sale? my eBay!
Reply 12241 of 30585, by TheAbandonwareGuy
Jed118 wrote:
I found a virus on a diskette I installed a game onto a client from. […]
to this lot:
What type of virus that would be found on a floppy would be any sort of threat today?
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 12242 of 30585, by MMaximus
It certainly is if you use this floppy on a vintage machine with an older OS!
Hard Disk Sounds
Reply 12243 of 30585, by Warlord
ThinkPad 770x w/ SelectaDock II
300Mhz P II
512 Ram
Trident 975 8MB
440BX Laptop 🤣
SB64G, Voodoo2,Intell 100s Installed in the Dock
IBM DEVA Mpeg2 Decoder + IBMVCAP Only 30% CPU utilization on Pentium 2 300 MHZ
MDK Performance
Reply 12246 of 30585, by aaronkatrini
Went on a 3 hour train ride to buy a 3DFX Voodoo 3 3000 with a BLACK HEATSINK. I'm so fking happy right now.
Reply 12247 of 30585, by cyclone3d
Sorta retro activity related.
I had a really trashed PCChips motherboard box that I was going to throw out.
Then I was working on my John Deere 285 Lawn tractor and needed a gasket fore the oil filler tube.
Noticed that the top layer of the corrugated cardboard for the PCChips box was the perfect thickness for the gasket so I made myself a gasket instead of having to wait at least 2 business days to be able to get one if I ordered it. Just enough silicone glue to make a super thin layer on each side of the gasket when installing and it is as good or better than a stock gasket.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 12248 of 30585, by wiretap
Got a new XP rig test booted and partially built.. bought the motherboard as broken, found out that the only problem was a dead CMOS battery. Other than that, it looks brand new. Weird that it wouldn't boot with a dead CMOS battery. Might have been due to not being able to save memory timing/voltages because it kept throwing the bad memory beep code with everything I put in it.
Specs:
ECS KN1 Extreme
AMD Athlon64 FX-57
Thermaltake Big Typhoon CL-P0114
2GB (4x512MB) Crucial Ballistix Tracer DDR500/PC4000/CL2.5
Nvidia GeForce 7800GTX
Coolermaster Mystique "Xoxide/Kikboxes High Roller Case" I won off an Xoxide contest
Next up:
- Install WD Raptor X
- Install DVD-ROM
- Sound card, maybe (DMX6fire or SB Audigy2 ZS)
- Install Windows XP
My Github
Circuit Board Repair Manuals
Reply 12249 of 30585, by TheAbandonwareGuy
wiretap wrote:
Got a new XP rig test booted and partially built.. bought the motherboard as broken, found out that the only problem was a dead […]
Specs:
ECS KN1 Extreme
AMD Athlon64 FX-57
Next up:
- Install DVD-ROM
What sense would a TerraTec DMX card make for gaming? An X-FI would make much more sense for a build from that era.
Reply 12250 of 30585, by henryVK
I finished making this screen bezel for my portable PC case:
5leKTh1.jpg?1
There's more pictures in the thread:
LCD Portable PC clone, display replacement
Reply 12251 of 30585, by wiretap
I don't believe I said it would be used for gaming. I had some other uses planned for it, such as audio/video work - I mentioned the TerraTec card and Audigy2 ZS since I have those on hand with convenient front I/O panels.
My Github
Reply 12252 of 30585, by bjwil1991
Cleaned all 14 of my Nintendo 64 game cartridges with DeoxIt and cotton swabs (Q-tips) and the console itself (cartridge slot and left controller ports). I also oiled the heatsink fan for the Socket 5 build a fellow Vogoner sent to me.
Planning on replacing the left controller ports, the cartridge slot, and the casing as it's been broken for a long time. Might do an RGB mod on it.
Reply 12253 of 30585, by kalm_traveler
Trying to get this new retro setup going... out of ideas on why it won't POST with the Corsair HX1000 but works just fine with this ancient VPower 400w hunk-o-junk.
The attachment 20190710_194906.jpg is no longer available
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 13900ks, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
Reply 12254 of 30585, by canthearu
The HX1000 probably doesn't have enough 5 Volt power for it. The Vpower 400W hunk of junk is probably a 3.3V/5V focused PSU, which is why it can handle it better.
Reply 12255 of 30585, by kalm_traveler
I thought that as well, but after looking at the numbers I don't think that's the problem...
There are 4 pins in the 20 pin ATX connector which are +5v, and each pin per spec is only rated for 6A, so 24A of +5v total. This VPower LC-B400ATX has 28A on +3.3v, 40A on +5v, and 17A on +12v rails while the Corsair HX1000 has 30A on +3.3v, 30A on +5v and 100A on +12v.
Given that the VPower has 10A more on its 5v rail I also assumed that to be the reason, though pulling over 30A just to boot up seemed a bit outlandish (I was trying with only the CPUs, 1 RAM stick and an AGP card installed).
However... since 24A is the max possible to pull over the 20 pin ATX connector, I am fairly certain that lacking amps on the 5v rail is not the problem.
Reply 12256 of 30585, by ODwilly
kalm_traveler wrote:
I thought that as well, but after looking at the numbers I don't think that's the problem... […]
Could also be with the giant distance of ATX specs. Like say for example. . .1.3 vs 2.0 or something. The way the PSU delivers power may have something to do with it, like the 12v rail not getting enough usage.
Reply 12257 of 30585, by PcBytes
That VPower is a Deer, and I know these are good 5v units after a good recap. Not all have beefy 5v parts on the 5v rail though, so crack it open and post a picture. I might be able to tell you how much it can output.
Reply 12258 of 30585, by kalm_traveler
Sure thing, I'll crack it open after work today and post it up. Tried to do a test setup with the rig parts last night (using a 20gb IDE HDD) and although Windows 2000 seemed to install fine, after that the system kept freezing so I gave up until I can either get the Corsair unit to boot it up or the 600w Enermax unit comes in and can be re-capped.
Also - not sure why I kept saying HX1000 for Corsair, is the 1200w model.
Reply 12259 of 30585, by oeuvre
Original Pentium III era hardware. Sent to a friend.
Case gutted.
Side panel which pops off with a push of a button on the front bezel.
Proprietary rear.
This needs some work if we're gonna convert it to ATX
Flattened/removed these little metal tabs
These clips hooked onto the old motherboard which used a non-standard layout.
The rear will have to be modified.
Actually, let's just cut it.
Cut out most of the rear.
Didn't want to cut off the very top of the rear end. Still, the case needs more work...
That is where this cheap donor ATX case comes into play.
Slice it in half.
Other side of case
Will preserve the back end as well so we can reuse it in the Optiplex
Cut off wheels are our friends.
Was really easy to slice through this one. Cutting the Optiplex was much more work since the steel wasn't paper thin.
Retrobrighted the case and painted a 5.25" USB 3.0 front panel ... slightly off but it's hard to find exact matching spray paints.
Dell Optiplex GX110 case
Corsair 750W power supply (cheapest name-brand power supply I found at microcenter at the time)
MSI Z270-A Pro ATX motherboard
32GB DDR4 3200 RAM (2x16GB)
MSI Armor RADEON RX580 8GB PCIe video card
Teac beige DVDRW drive
5.25 USB 3.0 front panel
Samsung 970 EVO 512GB NVMe SSD
Seagate 2TB 7200RPM HD
Windows 10
Left it in the sun a bit too long, some slight streaking is noticeable but only if you really look up close.
My motherboard's I/O shield is unfortunately missing... but did keep the original Dell PCI brackets.
The guts! Tidied up the wires in the 5.25 drive bays.
Lower part of the machine... the front panel is proprietary and was a pain to wire up. I don't have the HD LED working but everything else works fine (power LED, power + reset buttons).
That floppy drive is not hooked up to anything.
Here it sits in all its glory!
Speccy
Windows 10 system properties
Desktop
