OPL3LPT : OPL3 FM Synthesis on parallel port
Reply 180 of 202, by cde
I would like to report my experience with the OPL3LPT: I have found it to be excellent, in particular using it with AdLib Tracker II (https://github.com/pdewacht/at2lpt/) is simply a joy, the sound is really good.
Unfortunately my OPL3LPT became defective, probably during the two weeks after I received it (I hadn't used during this time). Even though the PC was turned off, I had kept it powered on with a Samsung USB phone charger, and without any load (headphones or speakers) connected.
My initial hypothesis was that because of a lack of a load, a program that would try to access LPT1 (such as Windows 98 during installation?) would have caused sound output that reflected in the amplifier due to the lack of a load, and damaging it.
I contacted Serge at Serdaco (dreamblaster on this forum) who very quickly offered a replacement OPL3LPT and also provided me with the information needed to locate the source of the issue. After probing with a scope with OPL3TEST running, it appeared no clock signal was generated for the YMF262, hence the culprit would be either the 14.3 MHz OSC or the HC04.
Serge kindly sent me the necessary parts to try and perform a repair. As it turned out the problem was indeed with the HC04, and replacing it completely fixed the issue. This part is not hard at all to replace if you have some chipquik and flux for desoldering.
My advice to other OPL3LPT users would be as follows: make sure your 5V power source is clean (perhaps this phone charger was a counterfeit?) and be careful of ESD. Even with the plastic cover, the back of the PCB is still exposed, and so it is best to manipulate the OPL3LPT by the sides. Consider powering off the OPL3LPT when not in use (I have bought https://www.ebay.com/itm/-/201640973904 to switch off the power more easily).
So in conclusion I'm very satisfied not only with this great product but also with the prompt resolution of this problem and the great customer service by Serdaco! 😀
Reply 181 of 202, by matze79
My OPL3LPT is not everytime detected i need to several replug it/repower it to get it finally working in the Testprogram.
This is on Escom Blackmate 386SXL 33Mhz Notebook.
Anyone has similar issues ?
maybe this is also power supply issue, i power it from 5V Rail inside the Notebook.
Co2 - for a endless Summer
Reply 182 of 202, by cde
matze79 wrote:
My OPL3LPT is not everytime detected i need to several replug it/repower it to get it finally working in the Testprogram. […]
Initially I tried with the USB from my motherboard (KT7A) but it was too weak.
Have you tried with an external USB power? Such as a phone charger.
Reply 183 of 202, by mothergoose729
Could you wire up USB power from a molex connector? That would turn and off with the PC and have plenty of juice.
EDIT: Like this https://www.amazon.com/Coolerguys-Molex-Dual- … r/dp/B006JCHN08
Reply 184 of 202, by cde
That's a great idea that I didn't think of initially. I will certainly try that as the 5V from my PSU (Seasonic brand) is certainly of better quality that a phone charger.
Reply 185 of 202, by dreamblaster
That's a good idea !
OPL2LPT, OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
Special vogons LPT bundle : https://www.serdashop.com/Parallel-port-retro-sound-bundle
Thanks for your support !
Reply 186 of 202, by matze79
Thats not possible, but i can use Step Down Converter from the 16-19V Input.
But.. OPL2LPT is always detected thats weird.
Reply 187 of 202, by kirikl
I'm sorry it is not exactly the topic. But Can I connect somehow Adlib LPT and Covox on the same port? Looks like impossible to find PCMCIA-LPT adapter (not cardbus!)
HP TC4200 2GB, SSD 120GB
Sony Vaio PCG-SRX99, 40GB HDD
Sony Vaio PCG-505TR, 32GB SSD
Sony Vaio Picturebook, Crusoe
Compaq LTE Elite 4/75CXL - 486
PowerBook G3 WS - PPC G3
iBook G3 Clamshell 300
Roland Sound Canvas 55ST
Reply 188 of 202, by Benedikt
kirikl wrote on 2020-01-09, 07:11:
I don't see how the Covox LPT DAC would interfere with the OPL3LPT, but the data for the OPL3LPT will certainly be audible on the Covox LPT DAC, so you cannot sensibly use them at the same time.
Reply 189 of 202, by dreamblaster
Are there any windows 3.1 users here ?
Apparently an updated version of msadlib.drv was created,
with support for OPL2LPT and OPL3LPT devices : https://github.com/andreiw/adlib21
Reply 190 of 202, by appiah4
dreamblaster wrote on 2020-02-09, 19:20:
I have WFG 3.11 on my current daily retro driver but no LPT devices to check, sorry for not being able to show up for this.
Reply 191 of 202, by jaZz_KCS
appiah4 wrote on 2020-02-10, 05:59:
I will test this today, very excited.... On a semi-related note: Is it at all possible to create a similar driver for the S2P device that allows it to be used as midi device within Win3.1/3.11?
Reply 192 of 202, by tyukok
Is it possible to install it on Windows 98? And, if so, what do I have to do? Do I have to edit system.ini manually?
Reply 193 of 202, by Jinxter
Is it possible to implement Reverb and Chorus effects on the OPL3LPT? That would also give mono games a stereo like effect.
Check out my YouTube channel: Retro Erik https://www.youtube.com/channel/UCSUf7nCpwTgFbjGmcTYGZEQ
My collection: https://retro.hageseter.com
Reply 194 of 202, by Jinxter
Have it been tried to get ADPTACH to patch Sierra AGI games? The AGI games support Composite CGA - 16 colors. It would be so cool to play CGA Compoiste games with Adlib support. That would get some attention.
Reply 195 of 202, by Jinxter
I was using the OPL3LPT on my IBM 55sx (386). And the OPL2TEST and the OPL3TEST had wrong notes. After some digging i found out that the problem was POWER.EXE in my config.sys (device=c:\dos\power.exe - for power saving in DOS). When removing the line in config.sys it was all fine. One can also type POWER OFF after boot to disable power management.
Reply 196 of 202, by Jinxter
I am flooding the thread with stuff. Sorry
Tip for removing noise:
I used a cheap USB charger from china. That gave me a lot of noise. Used the original Samsung charger and i had no noise.
Reply 197 of 202, by dreamblaster
Jinxter wrote on 2020-03-07, 20:16:
I am flotting the thread with stuff. Sorry
Thanks, yes this is useful advice !
Some chargers are only suited for .. charging...
Reply 198 of 202, by Jinxter
Suggestion.
Sometimes i need to go to the back of the PC and press reset. Instead i start the opl3test which resets the OPL3LPT.
What about a reset util, or a parameter to the opl2test that only resets?
Reply 199 of 202, by dreamblaster
Jinxter wrote on 2020-03-08, 12:07:
Suggestion.
good idea
