First post, by 386SX
I didn't remember that a Socket 478 solution having the i945 chipset with DDR2-667 and PCI-EX existed I've seen an Asrock and MSI board having that and I was thinking I could rebuild my old P4 3.4Ghz Prescott 478 config. It'd sound like an old but very fast single core SSE3 "modern" config with SSD.
Compared to the usual i865/DDR400 boards how faster it will be? And compared to an equivalent P4-661@3.4Ghz on Socket 775?
Thank.
Bye
Reply 1 of 4, by BushLin
It'll be a little faster for using the 945 over the 865, you'll lose Windows 98 compatibility but gain access to PCI-E graphics cards; it will still have severely lower single threaded CPU performance than a Core2 on an 865 and have no compatibility advantages over the even faster sandy bridge platform in Windows XP.
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 2 of 4, by The Serpent Rider
ICH6 and 7 are still compatible with Windows 98 unofficially. Although Intel LAN (chipset integrated) won't work and USB 2.0 ports will work in USB 1.1 mode.
Drivers are here: http://windows98.xf.cz
P.S.
I doubt i945 will have any significant perfomance benefits over good i865PE or i875P board.
Reply 3 of 4, by agent_x007
You can abuse 4GB of RAM :
The attachment cachemem.png is no longer available
The attachment cachemem0.png is no longer available
PCI-e GPUs :
The attachment Fire Strike Ultra.png is no longer available
AND if you sources :
The attachment Fire Strike Ultra OC2c mini.png is no longer available
Even NVMe SSDs (second PCI-e slot required, if you need PCI-e GPU) B)
Reply 4 of 4, by 386SX
agent_x007 wrote:
You can abuse 4GB of RAM : […]
PCI-e GPUs :
Thank you all. I was thinking to rebuild a main config using a "fastest" single core cpu and the two choices would be or the socket 478 3.4 Prescott I have or the socket 775 661 3.6 depending on which mobo I'll buy.
