First post, by Dominus
- DOSBox Moderator
As always I'm trying to get this one favorite program to run in Dosbox/windows 3.11 combo. I'm talking about the shareware program Inner Space. I licensed it ages ago and it is working correctly when I run it from a boot image (with Windows 3.x installed) but never got it to work correctly when I run it on "plain" Dosbox. Finally I found the problem is that the game writes the hdd serial number to the main exe.
So the question is if there could be something added to Dosbox to specify the disk serial number, similar to how the drivelabel can be set?
