luckybob wrote:OOF
Without going into detail, that PSU is TRASH.
It maybe working right now, but those anemic parts mean that is probably a 200W power supply, with a 400W label.
haha yeah doesn't surprise me.
I'm still confused how the Corsair HX1200 is not booting the Tyan dual CPU board, while this is though.
On a funny note, I didn't have any spare normal 80mm case fans laying around, but I have 2 Thermaltake Volcano 9 coolers in box, so I used one of those fans to replace the stock PSU fan in this unit. Using the thermo sensor included and turning the fan speed knob all the way down I had incorrectly assumed that this would be quieter than the worn-out stock sleeve bearing fan.
I was wrong. SO wrong. It sounds like a jet engine now (very much like a server PSU if you've ever been in a data center) which I suppose has the benefit of keeping the weak internals very cold.
Kind of makes one wonder how in the world Thermaltake ever marketed that fan as 'smart and silent', given the slowest it wants to run seems to be in the trillions of RPM.
************* EDIT**********
So funny thing... the Enermax 600w unit came in and just out of curiosity I hooked it up to this Tyan board to see if it would POST. Nope. Same behavior as the new Corsair unit - fans, drives, etc power on and stay on but no POST at all.
With an old PSU is that indicative of bad caps? I am really stumped now if the Enermax unit is fine but also won't POST this board, while the VPower 400w unit will.
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 13900ks, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
