First post, by T-Squared
- Member
I've been having problems with a 128 GB USB Flash Drive, suddenly-freezing transfers of which seemed to start intermittently a few months ago, and now every time I transfer data from said flash drive to the hard drive. Also, Scandisk reports cross-linked clusters (in short, files jammed together, with no concept of personal space. 🤣) that it needs to fix, every time. I've also had to reload the system's registry once.
I guess Windows 98 doesn't like drives higher than 127 GB... (Given what I've heard about support in LBA drive geometry, or something like that.)
I'm buying some cheap 4 GB flash drives, hoping to alleviate the problem, since the files that I transfer aren't THAT big.
