First post, by LordPatraxX
Hi guys!
I downloaded UFO-Enemy Unknown and I can't run it with dosbox 0.63. I must say i run dosbox on an eMac G4 1GHz with 640Mo SDRAM, running Tiger 10.4.
But i saw on your website that the game worked on OS X.
http://dosbox.sourceforge.net/comp_list.php?s … D=1334&letter=U
When i try it says:
"Error 35: Unexpected Interrupt=0000 in DOS4GW.EXE at 0080:0918 code=0000 ss=0090 ds=0158 es=0000
ax=3E05 bx=0005 cx=000E dx=0750 sp=220E bp=9A4C si=5036 di=696F"
I read elsewhere it might come from a corrupted file problem. Since this file exists in other games like UFO2, i tried it, but i had the same problem. I downloaded another dos4gw.exe i found on the net, and this time the dosbox screen became crazy (printing strange caracters on screen)!!
Has someone already experienced this problem and been able to launch the game.
Maybe it's because i use a Mac?
If someone could help me, that'd be most appreciated! Thanks!!
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
a few weeks ago I fixed a few bugs in the paging code of dosbox.
those bugs made it impossible to run paging games on MAC based pc.
So in 0.63 it will indeed not work (but works on a intel based pc)
But When I release the next version it will.
Water flows down the stream
Reply 2 of 2, by LordPatraxX
aaawwwwww..... 🙁
Well, i'm looking forward to getting the next version! 😀
Anyway, i found another game i loved: Dungeon Master.
I always had the nostalgia of some games like this one, UFO or speedball, and owing to you, i can play it again.
Thanks a lot for that great gift!!!!
