Reply 20 of 29, by moawkwrd
wrote:Hi
You havent by mistake got one of the first P3 450MHz chips? if so they are a bit different and the bios may be upset. I had this issue when going from a P2 400 to P3 550. Board had issues like this until i found a BIOS update. (HP oem version of an ASUS board). After the BIOS it took an 800MHz on a slotkit.
Nope, definitely P2 450. BIOS recognises it correctly with the 4.5x jumper setting.
Xeon E3-1241v3 - 16GB DDR3 - Vega 56 - W10
PII 450MHz - 256MB SDRAM - Voodoo 3 3000 PCI - W98SE
