Reply 20 of 25, by The Serpent Rider
Because it's linear voltage regulator.
Reply 21 of 25, by gdjacobs
Which burns off excess voltage in the form of heat out of the regulator transistors, so low voltage processors like MMXs and k6-2s require more heat exhausted off the regulator package.
Reply 22 of 25, by Windows9566
I noticed that my TC430HX posts faster than the AN430TX when i did a side by side. the TC430HX posts almost instantly after powering it on, similar speed to the ASUS VX97 in my P133 build, and the AN430TX has a short delay before it posts after powering it on.
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 23 of 25, by dionb
Windows9566 wrote:
why does the voltage regulator next to the CPU socket get really hot when i run it for a while?
Because it's an old linear regulator so cheap & dirty and very inefficient. It basically just burns off the difference between 3.3V and 2.8V so by design gets hot.
Reply 24 of 25, by Windows9566
the TC430HX also showed the full 40gb when i booted the same Win98 SE installation on it. i just swapped from my AN430TX to the TC430HX to see what would happen. the Intel Marl locks up in the bios when i try booting drives over 32gb but the Tucson doesn't.
Reply 25 of 25, by Windows9566
jheronimus wrote:
I’d pick the TC430HX. It has a fast 430HX chipset that is at least on par with 430TX, working Turbo (sort of) and it’s made by Intel: these boards are solid and well documented.
With OS it’s rather a matter of choice. I don’t think you miss anything by sticking to Win95 on a Socket 7, but you’re not gaining anything either. Just pick the OS that looks better/evokes more nostalgia. I’d pick Win95 😀
I went with that board, i just like the bios better on the TC430HX than the AN430TX, plus it POSTs faster. i was thinking of using it for early 3d games and DOS games.
