Reply 29640 of 52929, by flupke11
Ok, end of my shopping spree (for now). At 35 euro, a great steal from the industrial archive of Philips:
477.55 KiB
2 racks from the Philips Plant in Hasselt, Belgium. Not a speck of dust on them and an overall high quality feel to it. Both were used in the production environment where CD and DVD-equipment was assembled and adjusted.
644.17 KiB
752.86 KiB
The "driver" pc has an AT power supply, even if the 14 slot-backplane is also ATX-capable. The SBC is i430TX based with a Pentium 233MMX with 2*32 MB SIMMS. Logically, it's running WINNT 4.0 which feels smooth on the Qyantum Fireball HDD.
704.71 KiB
The other one is fully ATX, based on the Abit AX5T, also an i430TX mainboard. Both DIMMs occupied, I forgot to jot down how much ram it has. Sound is provided by a SB CT 2910 and VGA through a S3 Virge. The Pentium 200 is an OEM. The system runs on Windows2000.
586.53 KiB
Reply 29641 of 52929, by imi
that sure is a nice soundcard for an industrial PC, also those are really nice in general 😀
I went on a short trip to germany over the weekend... and had some unpacking to do 🤣
170.36 KiB
this is the loot from over a month.
I was flying home with over 20kg of mostly retro computer hardware in my carry-on, didn't even have much explaining to do... just "some motherboards and graphics cards" and an explosives swab later I was in.
put all the bulky and less valuable stuff in a package to send home with another 15kg or so.
got some sorting to do now...
this is one of the parts that was in there most precious to me, the first GPU from my first ever PC, one more piece in the puzzle to rebuild it 😀
210 KiB
Reply 29642 of 52929, by HanJammer
I found this pretty cool motherboard - supports 386DX, 486SX, 486DX, 486DX2 and other CPUs... 486 socket doubles as 387 socket. 386 is socketed so can be replaced easly with something else (I have Tx486DLC so I may want to check this option out). Upto 256kB cache. EISA slot, upto 32 MB RAM.
https://stason.org/TULARC/pc/motherboards/U/U … 6-BC3486UL.html
    1.99 MiB
Reply 29643 of 52929, by Anonymous Coward
OPTI Local Bus (OLB), not EISA. Is this board the FX 3000?
Reply 29644 of 52929, by Vegge
Are you sure? Seems to say EISA on the silkscreen by the slot. I could be wrong though.
Reply 29645 of 52929, by appiah4
Although I question the utility of an ISA only 486 board in the first place that is a fascinating piece of crossover technology regardless!
Reply 29646 of 52929, by HanJammer
Yeah, I did some more 'research' on it and it's OPTi Local Bus. Which is even better because I have fitting graphics card (S3 911) from which came with my other OLB motherboard. I don't have plans of putting 486 on it - it will be my ultimate 386.
Reply 29647 of 52929, by stalk3r
That's pretty brave, I was being much more cautious carrying only a crappy Trident ISA for the first time 😀
Reply 29648 of 52929, by Deksor
@HanJammer
Weird that they write "EISA" on the PCB when it's not. Kinda confusing ^^
But at least they had the excuse of saying it's physically the same slot. Because I've seen a 486 with vlb slots labeled as EISA 🤣
Reply 29649 of 52929, by derSammler
Since you can't tell EISA from OLB by the look of it, why do you even think it's OLB when it clearly reads "EISA"? I would expect to see OLB only on a board having an OPTi chipset at least.
Reply 29650 of 52929, by Anonymous Coward
Another way to know for sure is that it doesn't have an EISA chipset. Mini EISA boards normally have the HiNT chipset, and will typically have at least 3 brown slots. OLB boards almost always have one...maybe two slots.
Reply 29651 of 52929, by Anonymous Coward
OLB was used by other manufacturers, not just OPTi. I think the "standard" was relatively open. You can confirm this if you dig in old magazines.
Reply 29652 of 52929, by HanJammer
- Because fellow Vogon-ers say this board is OLB in other threads, for example:
BC3486UL UMC Motherboard + Tseng ET4000AX OPTi Local Bus VGA PRICE?
- Because jumper settings states this slot is for "local bus" cards and EISA is not a local bus.
https://arvutimuuseum.ee/th99/m/U-Z/34310.htm
But yeah, the silkscreen definitaly says EISA.
Reply 29653 of 52929, by Grzyb
That card may be EISA, be careful - Re: EISA Graphics / Video Cards
Reply 29654 of 52929, by HanJammer
Well, but it was in a computer which had Puma-200 motherboard and I used it with this mobo - Puma-200 has 3 "local bus" slots (one for CPU module only) and is opti based. I'm pretty sure information in above thread is incorrect (about OLB cards have only Tseng chipsets) - this is one of these SVLB cards.
736.86 KiB
117.6 KiB
Reply 29655 of 52929, by Grzyb
OK, then it must be Opti Local Bus.
BTW: that card has VRAM, rather than regular DRAM, right?
Reply 29656 of 52929, by Deksor
Be careful with infos coming from TH99 as I found many mistakes here. Don't take them for their word.
Reply 29657 of 52929, by appiah4
Got this lot for $20 including shiping. I think I need to stop, I have more stuff than I will ever need at this point. This is my 6th 486 board, I doubt I need more. I may buy a few more 386/286 and some 3dfx stuff (In particular I need a Voodoo 3 PCI) but for 486 and later stuff, I'm full.
181.4 KiB
No cache on the motherboard kind of sucks but I have cache on all my other boards so I can always borrow from them if I choose to use this.. Regardless, there's nothing particularly unique about this board, I may just sell it off.. I needed a fast non-MMX Pentium (the fastest I had was a 133) so the 166 was welcome. As for the UMC U5S, I already had a 33 but wanted a 40, but a second 33 could be useful for a trade somewhere..
Reply 29658 of 52929, by Cyrix200+
What's the card on the top right of the picture?
1982 to 2001
Reply 29659 of 52929, by appiah4
It's a cheap (possibly locally made) 512K trapdoor memory expansion for the Amiga 500. I have a few of these already but it was in the lot so I said why not.
