Jo22 wrote:Hi! My PAS16 cards can be fully configured by the install program, which in turn,
sets up autoexec.bat and config.sys accordingl […]
Intel486dx33 wrote:Does anyone know who this Sound card is programmed ?
Do you need to run the install program to configure the eprom on this sound card ?
Or can you just change the settings in Autoexec.bat and config.sys ?
sets up autoexec.bat and config.sys accordingly..
That being said said, maybe the older cards require jumper settings.
Or feature physical jumpers to allow choosing default settungs, not sure.
http://www.vogonsdrivers.com/index.php?catid=40
Edit: IRQ and Port (220 ?) may also refer to the Thunderboard part, not sure.
DMA sharing could be required if multiple PAS16 cards are being installed in a single PC - again, not sure.
Yeah, I tried that. I performed a clean install using the PAS16 install package from Vogons library.
This install program is a Cadillac compared to the Sound Blaster install program.
The PAS16 installer scanned for DMA and IRQ settings and then completed. It was that easy.
Awwww.....But it did not work. When I run “cusdiag.exe” utility which tests the card for functionality.
It list that the card is not assigned an IRQ and DMA address ?
But when I look at autoexec.bat and config.sys the PAS16 installer put the correct entry settings in these files.
So I think the jumper to select which IRQ the card is suppose to use needs to be set correctly first.
I think it’s jumper section J12 in the photos I posted.
But I have the card somewhat working just not reliably, but it does work.
I need to figure out these IRQ jumper settings and eliminate any conflicts.
