First post, by lost77
So, I have this simple BX board that doesn't have a monitoring chip or voltage control. If I put in a coppermine CPU it is detected as a Pentium III. The correct Mhz is also shown except for 1000Mhz which is shown as :00 (maybe it can't display 4 digits). The system works fine but i'm am wondering what kind of voltage it is getting. My coppermine CPUs work at 2.0v but I would rather not run them like that for long.
I don't have any experience measuring voltage from a VRM but maybe you guys can help me.
Here is a picture of the CPU area:
https://imgur.com/yd1yXMN
Reply 1 of 3, by andrea
Check between the tab of the two mosfets and ground, one should be 5 Volt and the other should be Vcore.
Andrea
Reply 2 of 3, by lost77
Thank you very much. I used a molex for ground.
Deschutes 300Mhz: 1.94v
Coppermine 733Mhz: 1.61v
Coppermine 1000Mhz: 1.66v
It is under-volting some but so does the testing PSU. Main thing is they are stable and running cool 😀
Reply 3 of 3, by ph4nt0m
If they work without any mod to the board, their voltage must have been sensed through the VID pins and set up accordingly. The Coppermines require 1.50V to 1.75V depending on a model.
My Active Sales on CPU-World
