First post, by RiP
I have found a Trident 8900CL 1MB 16-bit ISA card (PTI-223CL) which has a strange problem.
All of its eight DRAM chips are fine and have been tested. Anyway to fix it? 😕
Note: If I run it with 512/256KB of VRAM, I get only white screen.
    333.15 KiB
Reply 1 of 5, by Tiido
Looks like one of the lower address lines is not functioning on VRAM side of things.
Reply 2 of 5, by root42
nnEEeegg ttrrAall!
Tiido is probably right. Photos of the card? Did you check solder joints?
YouTube and Bonus
Reply 3 of 5, by Scali
Could just be a broken ISA slot, or perhaps a dirty/damaged contact on the ISA connector?
Try inspecting and cleaning the contacts on the card, and see what the card does in other ISA slots?
Reply 4 of 5, by Tiido
With a broken ISA slot side of things the video BIOS would be unreadable and the machine would beep with no video card error since BIOS checksum cannot be verified.
