Reply 81 of 189, by elianda
Could you check your setup again for XL-R8R with GF 256?
If you look at this capture from a rather old i740:
https://www.youtube.com/watch?v=XDxjuXikgs8&t=1552
the GeForce256 capture seems to be considerably more blurred in the textures.
Youtube Channel
Reply 82 of 189, by wbhart
It's amazing how many YouTube videos there are without real hardware. It's the same with games; everyone uses DOSBox.
I find it much better to see the real hardware running it because you can see the real framerate, there's no stuttering and you can do frame by frame analysis if you want to know how something was done. You just don't get that with DOSBox.
YouTube Channel - PCRetroTech
Reply 83 of 189, by elianda
It is probably not the best thread location to open this box here as arncht captures from actual hardware.
However I have to admit that this is indeed a problem, mostly because it is usually nowhere documented and quality checked vs. captures from real hw. (also the rather common wrong aspect ratio problem, because people don't care)
This leads to situations where discussions start under videos from real hw, that on some other capture from emulator the sound is brighter/speed is faster/slower and so on. I think that a real system is still the reference. And there are all kinds of real systems that might sound/look slightly different. Still.
Youtube Channel
Reply 84 of 189, by arncht
elianda wrote:
Could you check your setup again for XL-R8R with GF 256? […]
What should i check? I prefer basically the def settings in the dev tweak, just i changed the r9800 ogl texture filtering, because it looked like a 16 bit filter (striped).
But the mipmap, etc is the def, no forced aniso, etc. At the early cards eve4ry card rendered differently.
I also careful to use the authentic drv, not a late version.
Overdoze of the demoscene
Reply 85 of 189, by elianda
Hmm, I don't know. I just noticed that it looked more blurry on the GF256. I would expect that the textures show at least the same sharpness on a much newer card.
I have a setup with a GF2 Pro and 12.94 driver here and can have a look if it shows the same blurryness on XL-R8R.
Youtube Channel
Reply 87 of 189, by arncht
RealTech - Countdown (1995) demo on retro PC
Strike Commander (1993) PC game @ Roland MT-32
Reply 88 of 189, by Scali
Yes, I have a GF2GTS, and textures look very sharp in XL-R8R (by the way, there are commandline switches to select resolution or run it in 32-bit mode instead of the default 16-bit mode, to get even better quality. I've also made a utility to select videomode).
I expect the GF256 to have the same sharpness, because it's basically the same GPU, with the same texture units and all that.
If it's really that blurry, it must be a driver issue. I see no reason why it should be that blurry, because these cards had plenty of horsepower, and their speed and image quality were their selling point over the competition.
Reply 89 of 189, by arncht
That is simple... try out with the default settings with the old drivers. And you will get the answer. I never tweak any settings, i want show, how it looked at the biggest part of the users in the past.
It was the 3.68 from 99, i did want to swap between every captures.
    808.22 KiB
Reply 90 of 189, by arncht
Astroidea - Prostate 666 (1996) demo on retro PC
Doom II: Hell on Earth (1994) PC game @ Gravis Ultrasound
Reply 91 of 189, by arncht
Complex - Dope (1995) demo on retro PC
Games with Roland MT-32 music on retro PC
Reply 92 of 189, by arncht
Pulse - Tour (1998) demo on retro PC
Alone in the Dark (1992) PC game @ Sound Blaster Pro 2.0
Reply 93 of 189, by arncht
Shock! - E:RROR 808 (1996) demoscene demo on retro PC
The Lost Vikings (1993) PC game @ Roland SC-55 Sound Canvas
Reply 94 of 189, by arncht
Orange - The Nonstop Ibiza Experience (2000) demoscene demo on retro PC
Silverball (1993) PC game @ Gravis Ultrasound
Reply 96 of 189, by arncht
Pulse - Reve (1995) demoscene demo on retro PC
Extreme Pinball (1995) PC game @ Gravis Ultrasound
Reply 97 of 189, by arncht
Astroidea - Mutha (1996) demoscene demo on retro PC
Sam & Max Hit the Road (1993) PC game @ Roland SC-55 Sound Canvas
Reply 98 of 189, by arncht
Scali wrote:
Yes, I have a GF2GTS, and textures look very sharp in XL-R8R (by the way, there are commandline switches to select resolution or […]
i compared side by side with the 6.50, for me it looked the same. the default control panel settings are not the same.
for me more annoying the vsync (with high fps) - it looks always sluggish, the ati 9800pro was very smooth.
Reply 99 of 189, by arncht
Threestate - Nowhere (2000) demoscene demo on retro PC
Doom II: Hell on Earth (1994) PC game @ Roland SC-55 Sound Canvas
