First post, by Wandrell
When I try to play this game i get "system timer 2 error", which I have been unable to avoid with any configuration.
Without DosBox also there is no way, as Windows does not read the CD.
Data:
Motherboard: KV7(VIA KT600-8237)
Processor type: central processor, 2250MHz maximun speed
RAM: 512MB
Video: nVidia Geforce FX 5200
System: Windows XP
DosBox v0.63
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
did you try starting the game twice in a row ? (so after the error start it again)
Water flows down the stream
Reply 2 of 2, by Wandrell
It doesn't work. I can only configure the game. Perhaps it is related to how the game works, as it seems that it comes installed in the CD, only a few archives are copied to the hard drive and the game should be loaded from the CD.
