D-Fend Reloaded (DOSBox frontend)
Reply 2220 of 2285, by Avenger
twiz11 wrote:
well if you drag the whole folder "terminator" into d-fend, most of the time its got a pre-configured profile, like if you drag and drop quake or doom...
I figured out the problem.
Since the additional commands section only has a single line to enter text you have to seperate each command with "&&" characters or else D-Fend interprets it as one single command which obviously doesn't work once DOSBox boots.
Reply 2221 of 2285, by svfn
Hi, I have found that in Windows 10's High Contrast mode, the "Choose File" buttons in Profile Editor>Profile and Starting section don't open, does nothing when clicked. But disabling High Contrast and the buttons work normally. The buttons in Profile Editor>Directories work regardless though.
The attachment DFend_2019-03-05_17-27-16.jpg is no longer available
SS7: K6-2/350 | FIC PA-2013 2.1 | 32MB PC-100 | 3dfx V3 2000 AGP | AWE64 CT4520 | Win98SE
On MobyGames
Reply 2222 of 2285, by Nowhere Girl
GalaxyHigh wrote:
I've hit a problem when trying to view games in Screenshot mode. If I try this view (which has been working fine up until now) the "user defined information" fields start to cross one another and half of games it can find do not displaying their thumbnail images or pop up in the wrong field. (Please see attachment to make sense of this rambling).
I'm getting an error message stating "Access violation at address 004F6379 in module 'DFend.exe'. Read of address <variable 8 letter string>" for games catalogued under W and a different address message for games begging with X.
I haven't had this problem before, but I too have just hit it. Please tell me what to do, I can't view any screenshots in DFR. Sure, I can view them directly in the folder, but to be honest - screenshots are the main reason why I use DFR, I feel into a screenshot-collecting mania...
Edit: I checked further and this bug only appears for the "Book of Unwritten Tales" series. I don't know why, these are not the only games which don't even need DFR (that is, modern Windows games*), but I have created DFR profiles for them just to keep screenshots...
*By the way: running Windows 3.x games now seems much harder than running DOS games...
Edit 2: please help... I found what is different: the screenshots which trigger this bug were made with another program. I normally use IrfanView for catching screenshots in non-DOS games, but somehow it didn't work in BoUT 1 and "The Critter Chronicles" (prequel. I played the games according to plot chronology, that is, "Critter Chronicles", BoUT 1, BoUT 2). What sets these games apart is that they don't have a windowed option, to turn off fullscreen I had to install a hex editor and change a tiny bit in the code - perhaps it has something to do with the game not accepting IrfanView. I used Gadwin PrintScreen instead. However, superficially there's nothing different about these screenshots - the same size, same format (PNG)...
BoUT 2 accepts IrfanView. I decided to check it after a short while of playing the game, switched to this program and yup, the later screenshots which were made in IrfanView open just fine in DFR, no bugs...
I'll try a simple solution: cutting the image, pasting to a new file - just in "Paint XP for Windows 7" (my basic graphic editiing program - I just can't use new Paint) - and I'll see how these new files work... But please respond anyway.
Reply 2223 of 2285, by widhie75
Latest version of dosbox (v0.74-3) has been release on June 2019.
any plan of d-fend reloaded will release next version ?....... 1.45 maybe?
Reply 2224 of 2285, by IIGS_User
Author's last visit at this site was back in 2k16, no idea about.
Klimawandel.
Reply 2225 of 2285, by widhie75
well i think it's time to update dosbox manually
Reply 2226 of 2285, by alberthamik
I sure hope D-Fend Reloaded comes back to life for 0.75, I had problems getting it to work with SVN builds.
Reply 2227 of 2285, by Dagar
What problems?
Working fine for me with the latest SVN, latest ECE and vanilla.
Reply 2228 of 2285, by kolderman
Can the source code for dfend reloaded be released?
Reply 2229 of 2285, by Qbix
Rank DOSBox Author
DOSBox Author
It is open source...
just look a bit more closely on the downloads page
Water flows down the stream
Reply 2230 of 2285, by kolderman
That's good. I might look at fixing the downloads to various game sites to get images etc. It's still by far the best launcher around.
Reply 2231 of 2285, by kolderman
Delphi. Ugh.
Reply 2232 of 2285, by IIGS_User
kolderman wrote:
Delphi. Ugh.
So no chance you could pitch into the development?
Klimawandel.
Reply 2233 of 2285, by kolderman
IIGS_User wrote:
kolderman wrote:
Delphi. Ugh.
I had some strange belief it was in .NET. I would have to research what tooling I even need to build this thing. Is it worth keeping Delphi project alive? Will it be supported on modern Windows going forward? Maybe rewriting in PyQt would be better, but I don't have that much time.
Reply 2234 of 2285, by IIGS_User
Nö. Probably, starting from scratch would be the better option then.
D-Fend, D-Fend Reloaded, D-Fend Renewed?
Klimawandel.
Reply 2235 of 2285, by wolf
I loved this program!! Used it to fast set up my games and used the shortcuts you can make to more easily put my dos games on frontends.
Reply 2236 of 2285, by badflame
Dagar wrote on 2019-09-10, 12:30:
What problems?
For example, inability to select shaders, Voodoo 3dfx or DirectX.
Reply 2237 of 2285, by HunterZ
Would love to see something that is updated to support official and SVN builds, plus some of the popular forks like ECE/DOSBox-X.
I keep thinking I should try to take a stab at it, but then I realize that C++ probably isn't the best language, and that I know nothing about good UI design.
(Edit: And also I don't have a lot of time either)
Reply 2238 of 2285, by kolderman
HunterZ wrote on 2020-05-08, 21:22:
If only it was written in C++. It is written in Delphi 🙁
Reply 2239 of 2285, by krcroft
Dosbox Game Launcher is actively supported by rcblanke, and is getting regular updates for various fork features. Also can scrape metadata and box art, which is really nice.
DOSBox Game Launcher (DOSBox Frontend)
