First post, by thevdm
- Newbie
Hi all, I purchased an SD to IDE adapter for use in a P3 based Dell T500, the adapter is an SD35VCO.
When installed it is recognised in the BIOS, looks fine and has the correct size listed. Fdisk will only see the drive if I turn LBA and DMA off in the BIOS.
After running Fdisk I am able to delete the existing partition and create a new one, reboot and then format the drive. Once formatted I can copy files to it, although the filenames seem to be garbled such as COMMAND.COM displaying as AOMMAND.AOM. As soon as I reboot the PC and try to switch to drive C I get the message saying the drive isn't formatted.
So far I've tried it as Primary master, Primary slave and Secondary master. I've used Sandisk 32GB, multiple Sandisk 16GB and a Sandisk 2GB (standard SD, not HC or XC) cards, all with the same results.
Has anybody else come up with this problem/is there a solution or would it be a case that the adapter is faulty or the motherboard just doesn't support it?
Gaming rig: Dell Dimension XPS T500 - PIII 500 - 288MB RAM - Voodoo3 3000 - SoundBlaster Live! Value - DVD-ROM - CD-RW - 3.5" 1.44 - 98SE & 2000 dual boot
A nostalgic pile of laptops from the late 80's to late 90s.
