First post, by Lostdotfish
So I picked up a Roland MT-32 a few weeks ago and I've been running it through ScummVM and DOSBox but decided I want a proper retro machine to use it with.
After a fair amount of umming and ahhing I've settled on a (not technically period correct) Pentium MMX based build. I managed to get a really good deal on the board in the image attached. (£35) complete with 64MB RAM, ATI Rage II DVD GPU and ESS ES1868F soundcard.
The board is (if I'm correct) an Intel 430TX chipset based board from Texas Instruments. It has 4 PCI and 4 ISA slots. Does anyone know what case will be suitable? All the ATX towers I can find only have 7 slots. I'm assuming the board is a standard ATX layout.
http://texas-micro.industrialpartner.com/sing … s/atx/ti5tt.htm
