First post, by Viper87
Hi
Im trying to install win2k on socket 7 pc and im continiusly getting into windows setup, this loop never ends.
My PC specs
AMD K5-PR133
128 MB SDR
Soltek SL-54U
Matrox G550
Seagate 7200.7 40 GB
Reply 1 of 8, by derSammler
Make sure it does not boot from CD over and over again. 😉
Reply 2 of 8, by Viper87
Its not booting from cd. Its Windows based setup not Dos.
I read rhat silimar problem occurs on virtual machines. Makeing delay of something helps but in my case idk what i have to delay since i have Real PC.
Reply 3 of 8, by Akuma
Yeah that can bite you sometimes, was it xp that came with the press any key to boot from cd ?
cant really remember. whatever he's installing from, he needs to disconnect it after the first reboot iirc.
Reply 4 of 8, by Caluser2000
There is a command line setup process. Is the installation media a burnt cd or the original pressed cd? Try copying it to a folder on the hard drive and install from there.https://www.itprotoday.com/windows-server/com … xe-windows-2000
Reply 5 of 8, by Viper87
All files have been copied to HDD and installatuon runs from HDD now. When i take out cd it start from HDD. But im constantly getting into setup when you have to put PC name date etc after. When i finish that PC restarts and everytging repeats.
Reply 6 of 8, by Caluser2000
Sounds like a flat cmos battery. Possible your hdd is a bit large for your mobo as well.
Reply 7 of 8, by bakemono
When it restarts does the Windows boot menu come up, and if so what options are displayed? Or maybe you need to mess with BOOT.INI
Reply 8 of 8, by Viper87
Problem solved, i reinstalled the system from another cd.
