First post, by repoman
I can't run this game, when I attept to run it in dos-box in says -
"file not found.c"
this is what I type in dosbox -
mount c c:\
c:
cd dreamweb
dreamweb
Keep in mind i installed the game in drive c:, and it is called dreamweb
or should i mount the cd-rom drive???
Reply 1 of 2, by eL_PuSHeR
Of course. It seems you need both your C: & CD-ROM drives mounted.
Game will record savegames and such to your C: and it also needs its cd to read data from it (intro videos, data, etc).
mount c c:\
mount d d:\ -t cdrom
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by qball
I get the same error message. First I tried the actual CD and mounted the CDROM Drive. That didn't work. Then I copied the contents of the CD to a mounted directory on the hard disk. That didn't work. Then I used an ISO of the disc on a virtual drive and mounted that, but that didn't work either. I guess Dreamweb CD just isn't compatible with DOSBox as yet. Although I recall the CD verson worked to a certain extent with an earlier version of DOSBox.
