First post, by Errius
Hi all. I am trying to update the BIOS on a Jetway J-542C and am having problems. The current BIOS is D05 and I understand the latest is D06. AWDFLASH.EXE gives the following error:
"The program file's BIOS lock string does not match with your system"
The BIOS file is 542cD06.BIN. I have also tried flashing the hacked 542CD06J.BIN version with the same result. I have tried two different versions of AWDFLASH with the same result.
Is there some command line parameter for AWDFLASH that needs to be specified?
Is this too much voodoo?
Reply 2 of 7, by Errius
"No check BIOS Lock". That option isn't listed in the AWDFLASH /? usage page. I assume it was left out because its risky?
ETA: this is the best description of the program options I've found, though it's in Russian: http://wiki.rom.by/index.php?title=AwardBIOS_Flash_Utility
Reply 3 of 7, by Errius
Thanks, that did the trick
    465.93 KiB
Reply 4 of 7, by AlaricD
Undocumented switches abound! Indeed, it is pretty risky because basically it lets you flash any ROM you please whether it'll work or not.
You're welcome! I'm glad to help!
