Well,
After some testing today with AT2 with musics, specially Wheelchair.dfm and comparing to YT video https://www.youtube.com/watch?v=p6IITanvS6Y&t=240s I got into some conclusions:
Cards with CS4232 & :
CS4289 - Sounds the same as CS4236 from video.
YMF289- Sounds like YMF289 from video.
I also tried the card I made, the Orpheus (still in tests)
CS4237 IFM activated and YMF289 deactivated , sounds like CS4236 IFM.
CS4237 IFM deactivated and YMF289 activated , sounds like YMF289 soundcard.
This doesn't say that Crystal FM sounds bad, I really like it, for my taste it's better than ESS. I like it crisp and still can handle low freq. (My opinion, not saying it's better than others).
With this, all I can tell is: if you have a cs4232 card with ymf262, keep it like that. If you have a CS4232 with CS4289, no place to solder a ymf262 and you are an OPL3 purist, change that to a ymf289, otherwise leave it as is.
Since I'm not an OPL3 purist I have 2 give reason to some users here, but hey, we are all here to learn something.
Here's a peak at my soundcard :
The attachment orpheus.jpg is no longer available
