First post, by Digidreamer
- Member
Assistance required, spent weeks trying to sort this, reading various forums etc. trying different cards as recommended.
I've converted a T5710 to windows 98SE, I path well trodden,
I need some assistance with adding pci sound card, I've tried the sb0090 Audigy, and ess solo 1 sound cards, both well talked about,
the drivers install, in the case of the Audigy, doesn't activate, and the ess, just no sound when everything seems fine,
the onboard sounds been disabled from the bios,
i'm using a generic pci riser, looks pin 1 to pin 1 etc.
does any one confirm that the hp riser is wired differently?
many thanks in advance
regards..
I Like Charity Shops, they're like steam and GOG but cheaper.
Dos 6.2 - HP7510 512Mb, 4Gb
