Reply 12700 of 27595, by GigAHerZ
At last, i have a 486 VLB system! I was missing a motherboard, but now i got it.
So obviously i spent huge amount of my sleeping time this night to build and set it up.
During this week, i hope to find time to set it up as a killer win 3.11 machine. (DX4-100MHz, 128MB ram, VLB IO and video, +sound + nic)
Reply 12701 of 27595, by Duouk2000
I started playing Baldur's Gate 2 in my Windows 98 PC (KTA7-Raid + 6800GT) but it runs like garbage. Tons of slowdown and I don't know why. Disabling directdraw acceleration helps for some reason when it comes to scrolling but the moment the game throws some effects into the mix it slows to a crawl. Maybe the 6800GT isn't playing nice with the motherboard? I'll need to look into it some more tomorrow.
Reply 12702 of 27595, by bjwil1991
Got the Armada M700 up and running with all the drivers and utilities. Got the battery calibrated and surprisingly holds a charge, and the CMOS battery has been replaced as the IR drivers wouldn't work without it for some odd reason.
Windows can disable the display stretching, but I cannot find a spot in the BIOS to disable it completely (although, DOS games do look good without the pixels being overstretched), or settings g the time and date for that matter either.
The Slot 1 build is postponed until I get replacement y SD-RAM and Slot 1 sockets as they are not working properly, even my contact cleaner doesn't do justice very well.
Reply 12703 of 27595, by appiah4
128mb ram is asking for trouble.
Reply 12704 of 27595, by GigAHerZ
Well... challenge accepted!
Reply 12705 of 27595, by janskjaer
appiah4 wrote:
oeuvre wrote:
IIRC there are 2 metal tabs that attach to the bottom of the front end of the floppy drive and you just slide it in there til it clicks.
Photos would be greatly appreciated.. I want to know if it is something I could maybe 3d print..
It is a metal tray that allows the floppy drive to sit in it. The tray has a metal surround that allows it to be pulled through the *front* of the chassis, behind the fascia cover. It can be released and then clicked back into place using the two metal tabs below the front of the drive. Because it consists of two layers, and is very particular in its design, it may be difficult to 3D print.
As you can see from the attached photos, there are 2 metal trays. The lower, empty one is for a secondary hard drive. I used to use if for a secondary 3.5" IDE HDD some years ago. Since moving to flash storage, the tray is now empty; simply held in place by 2 screws in the front of the chassis, located just below the floppy drive (see photos) The two trays are different from each other, as they were both machined by Dell to fit specific drives (1 floppy, 1 HDD). I suspect you would have better luck 3D printing the HDD tray as it is simpler in design and I don't see why you wouldn't be able to alter it to accommodate a floppy drive instead, which just screws into the front.
This is the best I can do for photos I'm afraid as I had to rush to take these photos before it was packed and sent off for storage (it will be stored for some time). There was no time to disconnect the cabling, remove the drive and remove the tray.
    426.8 KiB
    478.13 KiB
    429.3 KiB
    293.04 KiB
    315.82 KiB
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
Chaintech 7VJL Apogee
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
Reply 12706 of 27595, by PTherapist
Received an Xbox Original console that I ordered today. I never owned one back in the day and so I'm basically just plugging the gap of that era of gaming.
Haven't done much with it as of yet, just tested it is working and tested out a couple of games. It needs a bit of a clean and I haven't opened it up yet to check for any issues, I'll be doing that tomorrow hopefully. So far it seems to be working well enough though and I've been playing a bit of Halo 2 & Dead Or Alive 3.
The ultimate plan is to softmod it & upgrade the HDD. I can get started on all that just as soon as I receive the USB adapter I have ordered.
Reply 12707 of 27595, by Mister Xiado
For whatever reason, when I was softmodding my Xbox, I had to use my Xbox 360 to format a memory card to XFAT so the original Xbox would recognize it. Just a heads up, in case you have similar difficulties with the process. Also, keep your original HDD. It may come in handy in the future. That is, don't unlock it and reformat it for other purposes.
Reply 12708 of 27595, by appiah4
janskjaer wrote:
It is a metal tray that allows the floppy drive to sit in it. The tray has a metal surround that allows it to be pulled through […]
Thank you very much. Unfortunately, that bay is apparently a lost cause on my D333.. I will just keep the floppy where the zip drive was, and the zip drive will have to go into another PC..
Reply 12709 of 27595, by bjwil1991
On my Original Xbox, the old 10GB HDD blew smoke and I still have the 80GB HDD I replaced it with 6 years ago, and mine currently has a 480GB SSD with a SATA to IDE (Startech.com brand) and an 80-conductor IDE-40 cable (3 foot long). Revision 1.6b is the one I own and the clock cap is a higher quality than 1.0-1.5, softmodded my Xbox using the Splinter Cell exploit by copying the save directory and the other ones to the 80GB HDD using a newly created Xbox HD Maker software, unlocked the HDD, copied the directories on there, and locked the HDD.
Reply 12710 of 27595, by Murugan
Finally recapped my 3 RTC caps in my 3 Xbox Classics 😀
Replaced a buckling spring on one of my model F's but I still need to test it after reassembly. If it works, it was the easiest assembly for me even though I read horror storries about it :p
@Ptherapist: don't forget to repaste your Xbox and replace or remove the RTC cap.
Reply 12712 of 27595, by kaputnik
Whatever you do, don't miss the Knights of the Old Republic series, the Fable series, Psychonauts and Ninja Gaiden. If you're into driving games, the Burnout series are great too.
Used to love the SSX games too, they manage to catch the feeling of snowboarding somehow, and make those horns start growing, just as in real life 😁 Been skiing since I was a toddler though, dunno if those games are for everyone.
Reply 12713 of 27595, by PTherapist
Well as an update, I haven't gotten around to cleaning the Xbox all out etc yet, but I did go ahead and softmod it today. A relatively painless process and I had no issues with the 512MB USB memory stick I decided to use. It formatted fine and worked a treat.
I tested out transferring over a couple of games via FTP to the small HDD currently residing in there. I did struggle at first as most games wouldn't work, until I noticed my FTP client was set to the wrong transfer mode. With that fixed, it all went well.
Also just for fun, I installed XBMC too. I can imagine this was brilliant back in the day for it's multimedia abilities & app/game launching all under 1 interface, but I don't really have much use for it myself nowadays other than for the novelty factor.
Reply 12714 of 27595, by PTherapist
I've played quite a few of these games on PS2 & GameCube and I do love Burnout 3, so am looking forward to comparing the Xbox versions. I have to agree with you that the SSX games are quite fun, even if I do kinda suck at playing them. 🤣
Reply 12715 of 27595, by Caluser2000
Ran some 20 year old software on a 24 year old hardware.
    53.99 KiB
    124.82 KiB
Reply 12716 of 27595, by Sedrosken
Made a functional backup of my DOS install for my 486 laptop... unfortunately discovered that the hard drive in said laptop is likely dying. It can create files fine but any deletion totally corrupts the partition table and FAT, whether it be through del or deltree or whatever. I have an SD adapter on the way for it, but it's on the slow boat from Shenzhen and isn't guaranteed to work with its BIOS... I hope it's intelligent enough to let you use non-Toshiba hard drives.
Nanto: H61H2-AM3, 4GB, GTS250 1GB, SB0730, 512GB SSD, XP USP4
Rithwic: EP-61BXM-A, Celeron 300A@450, 768MB, GF2MX400/V2, YMF744, 128GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428 VLB, CT2800, 16GB SD2IDE, 95CNOIE
Reply 12717 of 27595, by Bruninho
Amazing! Which linux distro is it?
JOBS, Steve.
Reply 12718 of 27595, by Caluser2000
Turbo Linux 6.0(server version which doesn't have as many user applications) running Gnome 1.x with icewm window manager and Stone theme. Wish I knew back then how well you can customize linux. Maybe I would have adopted it earlier. Turbo linux was based on RedHat 6.x .so rpm based, but with some better setup tools. Biggest thing is getting over the file system layout and how to use a terminal. I just think of the command line as a more powerful Dos now, that can do far more.
Collecting boxed copies of old OSs is a hobby of mine. You can see the variations between distros. Some were more polished then others. Not all had the same layout, setup or way of installing software. Of course they were no where near as bloated back then as well. As you can see from the screen shot Netscape Navigator can make posts on vogons.org with no issues at all. Personally I think any computer hobbyist should have at least some experience with linux.
Reply 12719 of 27595, by appiah4
Caluser2000 wrote:
Turbo Linux 6.0(server version which doesn't have as much user applications) running Gnome 1.x with icewm window manager and Stone theme. Wish I knew back then how well you can customize linux. Maybe I would have adopted it earlier. Turbo linux was based on RedHat 6.x .so rpm based, but with some better setup tools. Biggest thing is getting over the file system layout and how to use a terminal. I just think of the command line as a more powerful Dos now, that can do far more.
I used RedHat 5.0-5.2-6.0-6.2 between 1998-2001 and yes, that experience taught me a LOT about computers.
