Reply 29980 of 56766, by yawetaG
wrote:There was some nastiness in the battery compartment, because of course there was, but fortunately it cleaned up OK and doesn't seem to have damaged the plastic. Apparently nicad batteries "leak" into a weird fibrous solid.
Er, no, that means you just were lucky. Normally they leak all over the place and destroy the battery terminals, which often may look somewhat fine but turn out to be so brittle they shatter upon touch. So better open it up and check for other damage.
Very cool machine, BTW. I would leave it as is, nice piece of history. You may want to trawl through Japanese webpages and see whether it can do more than just load stuff from the ROM, because it sure looks like a Western version of a Japanese "Office Assistant" machine (and some of those can do a lot, including sometimes play simple games).
