First post, by vmr_
Came across an interesting Pentium 60/66 motherboard from '94, which has the power connector slightly different than what I encountered until now.
Photos attached.
The attachment power connector 2.JPG is no longer available
The attachment power connector 1.JPG is no longer available
Is there a specific power source connector/adapter to be used? or the P8/P9 sockets work as well? If the latter, which would be the recommended way to connect, considering the narrow pins the socket has?
Also, socket on motherboard mises one pin (not soldered at all).
Thanks
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 1 of 10, by Predator99
Also have some boards with such connectors, think its standard P8/P9. To be sure you can measure connectivity against the known pins on the ISA-bus.
Reply 2 of 10, by vmr_
Noticed P8/P9 sockets have a second row of narrow holes, matching nicely with the narrow pins...
However, to connect it that way, the P8/P9 would switch position (but keeping black wires in the middle).
Reply 3 of 10, by derSammler
These holes are for releasing the contact springs, not for connecting to anything.
vmr_ wrote:
However, to connect it that way, the P8/P9 woouls switch position (but keeping black ires in the middle).
Don't even try, the pins are not symmetric.
Could you please show a picture of the whole board? If it's branded, the power connector is probably custom.
Reply 4 of 10, by vmr_
thanks derSammler, so it is the usual way to connect P8/P9.
Not tried yet, asking first 😀
Reply 5 of 10, by vmr_
The board is s Socket 4 one Daewoo branded, have no good photo of it. Need to do a good cleanup first, it is full of dust.
OPTi 82C596 (Cobra) chipset. Board is marked CPC-5200 - but have no other details about it. Would be great if I can find a manual or jumper settings for it.
Reply 6 of 10, by jmarsh
That LPT1 connector has seen better days.
Reply 7 of 10, by vmr_
Agree, cleanup and straightening some pins here and there 😊
Reply 9 of 10, by vmr_
MMaximus wrote:
I've encountered the same problem a while ago:
XT mobo in AT case: questions about PSU connectors
Thanks Mmaximus, this helps. Good intro for my next system on the list - an XT one
On using the AT P8/P9 on the XT-like power socket, it is my understanding the little fins (keys) on P8/P9 face the S-like plastic part of the XT socket.
So for my first photo, P8 is actually on the right, and P9 on the left side of XT power socket.
Reply 10 of 10, by CPU Galaxy
vmr_ wrote on 2019-09-02, 10:30:
Hi, I am desperately searching for a BIOS dumb of this Pentium Socket 4 board. Its the CPC-5200.
Could you upload a BIOS Dump here?
Thanks!
