Reply 20 of 23, by Cob
wrote:wrote:As in the 1.4 patch for USNF97? I'm referring to Fighters Anthology, patched to 1.02. The crashes aren't guaranteed but have happened during or on completion of some quick custom missions.
Whoops, I read it wrong. Regarding FA, try using my fix. You'll need MS ACT 5.x or 6.x to use it.
I actually managed to get this working with a fresh install using only bellarmine's fix (avoids issues related to changing compatibility mode to XP). My original install included the no-CD patch, so the issues might have been related to that.
I'll play around with it some more -- while having to use the physical disc again is a pain, I absolutely love having the midi music enabled.
