Dos Menus
First post, by Caluser2000
What Dos menus do have set up or used in the past. Direct Access was the main one used when I was at work in the earley '90s. In barracks I got Quick Menu III from NeoSoft (was OSCS Software Development Inc.). OCDS had some cool products like NeoPaint. It allowed you to run programs, had a few utilities like a calculator and had file management as well. If you has some ems available you could have a desktop background image. It's also cable of submenus and subsubmenus.Runs on an XT fine and covers CGA, EGS, Hercules and VGA palettes.
37.23 KiB
1.26 MiB
1.32 MiB
https://www.youtube.com/watch?v=aNEiKhJ5Co8
Reply 2 of 30, by Caluser2000
Yip it certainly is very customizable. I'll have a dig through the rest of my ye oldey software for more. I'm sure I have a few OEM ones that came with system I'd acquired over the years to take pics of. There was one freeware vga one that was very polished . It was done by a German chap I think.
Reply 3 of 30, by dr.zeissler
On ET4000/1MB it does produce wiered errors. In EGA-Mode it's OK, but therefore the ET4000 needs to be switched to ega "vmode ega"
and then the started game does only recognize EGA. I would love to use qm3 on my A2286/6 with ET4000.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 4 of 30, by derSammler
That's easy to solve. Create a small batch file as a starter for games. Something like:
@echo off
vmode vga
%1
vmode ega
Then instead of using "c:\games\whatever\game.exe" to start a game from QM3, you use "start.bat c:\games\whatever\game.exe".
Reply 5 of 30, by dr.zeissler
I considered this already, but there must be another Solution for getting no error's with an ET4000.
QM3 should have been tested on this tseng-cards. Perhaps it's because the cpu 286/8 is too slow?
I do not have a 386/486 with ET4000. All I have is an ET400/w32 onboard on a 486/dx2/66 but
there are no glitches.
Reply 8 of 30, by derSammler
"Desktop 2" from Felix Ritter is also quite nice. Similar to QuikMenu but with some additional functions to make it more OS-like. Did not use it yet apart from some testing, however.
There's an English version of it as well.
Reply 9 of 30, by cyclone3d
I never knew any of these existed back in the day.
I did use DOSSHELL and also have config.sys and autoexec.bat menus set up though.
How much RAM do these menu programs use up? Do they affect the speed of other programs running? I am guessing they don't exit themselves when a program is run from them.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 10 of 30, by derSammler
They don't affect speed. They also use almost no RAM. At least the ones I know work similar to DOS Shell: launching a program removes the menu from memory and hands control over to a batch file, which re-loads the menu after the program has ended.
Reply 11 of 30, by keenmaster486
I used DOSSHELL a long time ago, but I since dispensed with menus because of the memory footprint.
I flermmed the plootash just like you asked.
Reply 12 of 30, by dr.zeissler
I never used dosshell because it's so slow if you have lot's of files. I am a nc/vc user since 1988.
The smallest and fastest menu-system I have and probably will use on my A2286 is called "hard-disk-manager"
and I found it on my neighbors 8088xt laptop which he had purchased in the us and brought it
back to germany.
    113.41 KiB
Reply 13 of 30, by Caluser2000
That is the one I was thinking of. Magic Desk 3 iirc is another graphical Dos menu. Couldn't find it on the interweb. My search foo seems down today. I have a disk here with Magic Desk on it so will fire it up on the 286 sometime and post a pic.
Reply 14 of 30, by leileilol
This?
2.56 KiB
(Fans of Tech-Express may recognize this 😀 )
    MDESK322.ZIP
    158.16 KiB
    15 downloads
Reply 16 of 30, by dr.zeissler
yesterday I configured the basic-stuff on my A2286/8 with "The Hard-Disk-Manager" and all I can tell you is, that's superbe and fast.
I will defently use this for XT/AT/Tandy machines. 386+ I will go for something like QM3.
Reply 17 of 30, by Caluser2000
On GeoWorks Ensemble 1.2 Pro there is area you can set up to run Dos programs.
16.69 KiB
4.07 KiB
It was dropped from later versions of PC Geos.
Reply 19 of 30, by Orkay
back to germany.
I've got the same program, along with an earlier menu program that I found on some backup diskette of a relative's IBM XT (which was either trashed or given away around 1993, to my absolute disappointment). It even has a little screensaver!
    11.51 KiB
    4.48 KiB
