Reply 30261 of 52805, by imi
SpectriaForce wrote:
There's this old saying 'if it looks / sounds too good to be true, then it probably is'. The folks who sell scrap are often professionals; they know what they do. If they would identify really valuable stuff, then I'm sure that they would offer it separately. Yes, you can be a couple times lucky, but in the end you are just gambling 😉
yeah, I know it's all a gamble, and I have been very lucky on some, but it's just a pity if there is a nice gpu or motherboard in there, and then it's packed so horribly bad that something that looked fine on the picture just arrives completely broken... and since it's all sold as scrap anyways I don't think there's much room for recourse.
unfortunately it's far easier to find particular parts in scrap lots than to go looking for individual parts that get sold for insane prices.
local classifieds rarely have anything good, and they too ask prices similar to ebay already or are just gone before I get the chance ^^
but I've got good things out of them already and I'm probably going to concentrate more on building stuff with what I have now 😀
Reply 30262 of 52805, by jheronimus
jheronimus wrote:
Got a cheap Pentium III 1100 for a 100 MHz FSB today.
Nice. I wonder how far you can overclock it.
Nah, I'm not into overclocking retro hardware, which is why I wanted to stick with 100MHz FSB in the first place. I'd like to have a stable system even if it means I am losing a bit of performance. A system like that is plenty for nearly all late 90s games which is my primary area of interest.
MR BIOS catalog
Unicore catalog
Reply 30263 of 52805, by CrFr
CrFr wrote:
I'm on a shopping spree today :lol: […]
I'm on a shopping spree today 🤣
Got this Digigram VX222 sound card for 2,5€. If it's not very good, it's not a big loss. I think I'm going to use this on my new Intellistation. Too bad it didn't come with the breakout cables, it only has 3,5mm audio out on board. It is some kind of professional audio card with balanced inputs and outputs. Made in France. It has been very expensive card when new: https://www.studiocare.com/digigram-vx222-hr- … sure-i-o-s.html
edit: Found a cable pinout for this. Seems trivial to make a suitable cable actually.
Little update on this. I tested it, and it sounds awesome. I spent something like two hours just listening to this fine device. It even drives headphones well and loud, straight out of the 3,5mm connector. This must be the best 2,50 euros I have ever spent on hardware 😎
Not sure how it will do with games. This card is targeted for professional audio production, so it might do some unexpected tricks with games. I still don't have gaming capable AGP graphics card for that machine, so that part of the testing has to wait.
Reply 30264 of 52805, by imi
well my mood is up again 😀
I fished this out and cleaned it up, it was scratched to hell, there's a long scratch along multiple traces on the backside but they all seem intact, and one of the ICs is bent out of place + a few bent pins that are going to be easy to fix though... I just quickly threw it in to test and not only does it work, but oh my, the VGA output is smoooooth AF, so clean 😁, the ET4000AX I had in before was a bit noisy on certain background colors.
214.86 KiB
Reply 30265 of 52805, by SpectriaForce
imi wrote:
yeah, I know it's all a gamble, and I have been very lucky on some, but it's just a pity if there is a nice gpu or motherboard i […]
Some computer parts might look good from a distance, but especially parts from the 90's and more recent have (among others) very small SMD components, which can be easily wiped off. I once destroyed a perfectly fine Asus GF4 MX460 that way by trying to install a new cooler 😵 You can only imagine what can happen if you buy bulk scrap and everything gets mixed up during shipping. You would need to be able to inspect razor sharp high resolution pictures of the parts in advance, know how a good example of a part looks like and still have a lot of luck to profit from such scrap deals. Looking at the sold prices of > € 50 for a couple kilograms, I think that's pretty expensive with so much risk involved and no warranty.
Reply 30266 of 52805, by Cyrix200+
Unknown (for now) 486 EISA motherboard, marked 4FLUD-1. Keyboard connector removed for some reason, but looks okay otherwise. No battery damage (battery was also already removed).
KCLNUbzl.jpg?1
EISA cached IDE FDD controller:
dLkhY1cl.jpg?1
vVBtlqUl.jpg?1
FEh2GXVl.jpg?1
1982 to 2001
Reply 30267 of 52805, by Disruptor
Cyrix200+ wrote:
Unknown (for now) 486 EISA motherboard, marked 4FLUD-1. Keyboard connector removed for some reason, but looks okay otherwise. No […]
KCLNUbzl.jpg?1
This is NOT an EISA motherboard.
Look at the BIOS chip. Look at the chipset.
It seems to be an OPTI Local Bus.
Do you have a graphics card too?
Reply 30268 of 52805, by Vynix
Although EISA and OPTi Local Bus slots are similar and mechanically compatible (?), plugging a EISA card into a OPTi Local Bus slot is going to damage either the card, the motherboard or both.
Reply 30270 of 52805, by arncht
jheronimus wrote:
Got a cheap Pentium III 1100 for a 100 MHz FSB today. […]
Thing is, I've been looking for a 1GHz/100 Slot 1 CPU for my beloved 440BX system (in my signature) with no luck and this chip is even better. The only thing left now is to find a proper Slotket adapter. I have this one:
practically they do not really put to a bx in the past, they released just in 2001. the 900/1000mhz version is end of 2000 too.
Overdoze of the demoscene
Reply 30272 of 52805, by keropi
nice!
is it possible to dump the 2 roms the card has? I have one too but the stickers say it's v5.01 - wouldn't mind to upgrade 🤣
Reply 30273 of 52805, by sf78
I was in a hurry and almost skipped going to the local recycling center...almost.
SuperMicro P6DGH for 2€. 😊
773.59 KiB
https://www.cnet.com/products/supermicro-supe … -slot-1-i440gx/
Reply 30277 of 52805, by chose007
sf78 wrote:
I was in a hurry and almost skipped going to the local recycling center...almost. SuperMicro P6DGH for 2€. :blush: p3.jpg https […]
Man, what a funky board is this. Power conns are crazy too. And 72pins RAM for 2x slot 1 ... wow nice setup 😀
Reply 30278 of 52805, by derSammler
so yuo have some treasures for amiga? any accessories which are rare?
I own a CD32, two A600, two A1200, and one A500. All except the A500 are fitted with lots of expansion hardware. One A600 has an M-Tec 630 and an MP3@64 installed, one A1200 a Blizzard 1260 and uses a limited CD32-style case from Kickstarter. Also more common stuff like Indivision ECS and AGA, Prisma Megamix etc.
btw, there is some Amiga coverage: http://www.retro-net.de/blog-suche.html?tag=Amiga
Reply 30279 of 52805, by Bancho
Received a nice Gigabyte GA-486VS motherboard today. Battery had been removed and the appears to be minimal to non corrosion. Board looks to be in great condition. It came with a DX2 66 and 8mb Ram.
Set it up and it booted straight away so well happy! Looking at the board there is a space for a coin battery holder. Can anyone advise if its possible to solder in a holder? Is there anything that needs to be done to the board?
