First post, by Dirilu
Hallo guys...
I have this 3dfx voodoo 3 3500 COMPAQ TV Out AGP 16 mb card in my compaq. But where do I find a driver that works... 😢
This was not a card that was sold in a box right ... 😐
Hallo guys...
Standard Voodoo 3 drivers should work.
I have 2 of those cards, I use AmigaMerlin drivers, and mesafx for openql games. You need to manually put the dos ovl driver in a games folder somtimes for it to run, especially with DOS games that will run on a voodoo 3
That is the best Voodoo 3 card, a bit of a warning and sugestion these cards get quite hot, I recommend getting a slot cooler blower and install it next to the card so there is sufficient airflow around the heat sink.. Some people zip tie fans on it but I find that probably unnessary if u have good airflow from a slot cooler.
thanks guys.. I got it working like a charm. and yes it gets very hot. I will mount a fan on the cooler.. 😉
