Reply 320 of 548, by LABS
- Member
wrote:Hi, […]
finally had time to solder it.. but i don`t get it detected as SB,
Adlib works just fine.Checked for solder bridges etc. and found nothing 😒
ICs are correctly in position too 😒Any Ideas what i should check first ?
The board is not working correctly because you did not finish the assembly - i.e. the board should be cleaned from flux and excessive solder bits.
Do not ignore this, as flux can conduct.
While the board is dirty, its behavior is unpredictable.
Also the places in doubt should be put to order before powering up the card.
These are the first steps to do.
It is all written in the assembly manual.
