Reply 30340 of 52808, by HanJammer
JonathonWyble wrote:
Arctic wrote:
Luigi Colani passed away today.
Huh, sad. I can't say I've ever heard of him until now, when you said that. When I found his Wikipedia article, I found out that you were right. It also seems he was more in the automotive industry than the computer biz...
Yeah... Luigi "don't drink and design" Colani... he was generally in the design "industry" not really automotive nor computer industry. I think he also designed some home appliances and stuff like that. I never liked his projects - too freaky for me (I especially hate his Vobis cases - they always looked to me like some old hand driers from a public toilet)... Still he was an iconic designer.
Reply 30341 of 52808, by sf78
Went to recycling again. They had several early 00's AMD boards there for 2-3€ (CPU included), but I decided to skip them as I already have too much crap lying around. Instead, I have this weird fixation on AGP cards so I bought these instead:
495.61 KiB
9600XT
AH3450/512
Both 1€ a piece.
Reply 30342 of 52808, by appiah4
sf78 wrote:
Went to recycling again. They had several early 00's AMD boards there for 2-3€ (CPU included), but I decided to skip them as I a […]
9600XT
AH3450/512
Both 1€ a piece.
Did they by chance have an MSI KT3 Ultra/Ultra-ARU/Ultra2? Still hunting for one of these..
Reply 30343 of 52808, by HanJammer
Might be a bit problematic (unless you will find slightly used one or NOS - but it still may not work). It's a very good example of the 'capacitor plague' era motherboard. Every single KT3 Ultra and KT4AV motherboards as well other MSI motherboards from this era we had at work (K7D Master for example) died long time ago - one after another, due to capacitor problems which consequently led to blown voltage regulator circuits on them. I still have one KT3 Ultra which I will try to repair and I managed to get two K7D Master repaired but this era red MSI motherboards must be the most unreliable boards ever (they used cheapest caps available I think)...
Reply 30344 of 52808, by appiah4
I used to have one and I want to get one to recap; honestly it's a terrific board for retro purposes, Universal AGP and AthlonXP support..
Reply 30345 of 52808, by Daniël Oosterhuis
Went to the thrift today, and picked up some AGP cards and a special CD player 😎
The cards are an MSI FX5200 (mostly picked it up for that heatsink, already have this junky FX card), and an ASUS V7100 Pro 32MB GeForce 2 MX400. Both cards cost €1 each. I got one of those ASUS V7100 Pro cards from the same thrift earlier, but given they're rather useful as an affordable replacement for the GeForce 256, I'll gladly get another for that price.
Image removed for copyright reasons.
Now, about that CD player. It's a Philips model, it was untested and it only cost me €2. But I wouldn't post about it here if it were just a CD player, right? 🤣
Yep, it's a Philips CD-i unit! I did get another CD-i unit from this thrift before, but it was a VCR sized Matchline model with a dead laser. This one is a much compacter model, the CD-i 470. I much prefer this size of CD-i player, and it works just fine! It also has the Digital Video Cartridge, and came with a Video CD with movie highlights. The CD tray does need some attention, it screeches a bit when closing, and it doesn't quite lock, meaning that if you pick up the unit and hold it with the CD tray facing the ground, the CD tray will pop out.
One disadvantage of this unit is that it doesn't have RGB SCART or S-Video. However, mods exist to get this to work, specifically on Assembler Games (you might need to use the Internet Archive to open this link, the forum was supposed to shut down months ago and who knows when/if it will actually happen). I also don't have a controller, but an Arduino based solution exists for converting a SNES pad to the CD-i. I think I'll have some fun playing some mediocre games soon 🤣
Reply 30347 of 52808, by ShovelKnight
My Gigabyte GA-5AX has arrived today, looks to be in perfect condition, just a bit dusty.
I finally have almost all the bits to assemble a Super Socket 7 system:
- a decent motherboard
- a choice of AMD K6-2+ and K6-III+ CPUs
- 384 MB of PC133 SDRAM
- ESS sound card
- IDE SSD + 40 to 44 pin adapter
I now need to get a decent video card, a CD drive and a Gotek floppy emulator (in fact, I already ordered one but it seems to be traveling on a slow boat from China) and that's it.
Reply 30348 of 52808, by dionb
Received some small things today:
A 16GB PATA DOM (for my ultimate P3 Win98 machine), two 120GB Samsung SATA SSDs (one destined for my dual G5 PowerMac, the other for one of my sons' computers) and 5 OPL-2 chips.
At least, that's what the markings say and that's how they behave - I tested all five in my Snark Barker and they sound identical to the sixth chip here, the OPL-2 I already have. However they look rather different, with a (poorly tooled) circular notch instead of an indicator dot on my other one. These five are closer to what real OPL-2s look like, but with mfg dates indicating 2010, the inscription is as iffy as the 2013 on my 'old' one. But if they work, I don't care. I only needed one for an AdLib replica, and another for a friend. But five was cheaper than two 😜
Reply 30349 of 52808, by Grzyb
HanJammer wrote:
This XT clone. Works perfectly fine (judging by the files metadata it was last used in 1994 and was destined for a scrap yard recently). I even got XT keyboard with it for free.
Was that cat a part of the bundle as well? 😁
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 30351 of 52808, by HanJammer
Nope, that's my assistant, Wiorek (Chip), making general inspection of the hardware prior to the first run.
Reply 30352 of 52808, by liqmat
524.1 KiB
Noice! Have the same case for my restored 286-12 which I am getting ready to sell. Fantastic AT case.
985.82 KiB
Reply 30353 of 52808, by HanJammer
liqmat wrote:
The attachment IMG_20190916_205325.jpg is no longer available
The attachment 286-12.jpg is no longer available
Yes, that's very similar - main difference being mine has hinged upper cover...
I plan on refreshing it this weekend - it's in very good condition so it should came out nicely.
I also have another one of these which I keep for some older 286 build and one looking more like 5150 - both are cleaned now and look nice but I don't have more recent pics...
Reply 30356 of 52808, by cyclone3d
pan069 wrote:
cyclone3d wrote:
Gravis Ultrasound 2.4 boxed - this is my first GF1 based card
The attachment Gravis Ultrasound.jpg is no longer available
Holy shit. That thing must be worth a fortune. Show us some pics when you get it.
I actually had it when I posted those other pics. Just hadn't had a chance to take pictures. The outer box actually got a little bit messed up in shipping. 😢
1.12 MiB
1.08 MiB
793.84 KiB
747.5 KiB
704.03 KiB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30357 of 52808, by cyclone3d
And a few more:
1.02 MiB
- have the original envelope the disks, etc came in but I didn't figure a picture was needed.
849.08 KiB
340.38 KiB
861.47 KiB
YMF7x4 Guide
Reply 30358 of 52808, by appiah4
Damn you! I envy those desktop cases so much.. Not a single one to be found (in decent condition) where I live; understandable as computers were a VERY small market in a poor economy at the time, C64s dominated everything..
Reply 30359 of 52808, by bjwil1991
I wish I can find a Gravis UltraSound ACE cheap someday for my Packard Bell Pack-Mate 28 Plus to turn it into the ultimate sound card machine.
