First post, by th1r5bvn23
I spent a lot of time googling and using archive.org but only found IDE drivers for XP/Vista/7 and RAID drivers for 98/XP/Vista/7. Also downloaded driver packs from vogons driver library and Phil's site, but neither contains an IDE driver for Windows 98. So I'm here to request a latest IDE mode driver for Windows 98. Thanks.
Intel Pentium E5300, ASUS P5KPL-AM SE, 2GB DDR2 800, ATI Radeon X300 SE, Creative Sound Blaster PCI 128 CT5807
Reply 2 of 4, by jaZz_KCS
How do you know that his adapter isn't already running in SATALink (Ultra) mode as opposed to SATARaid (RAID) mode? I guess because there are no drives found at windows installation 😀
Anyways, for Windows 9x, you have to use the v1.2.0.5 driver that is labelled xp-2k, which also works for Win9x. Win9x Installation instructions are described in the readme under point 9 and 10.
As Warlord correctly stated, make sure that the adapter is running in non-RAID/IDE/Link mode (SataLINK) instead of RAID (SataRAID) mode. You can watch for boot strings upon bootup and tell which mode is being run.
Reply 3 of 4, by th1r5bvn23
Thanks for your help. I found V1.3.10.0 driver from 2009 archive of Silicon Image official website and that seems to work with Windows 98. Flashed IDE mode BIOS V5.5.0.0.
Reply 4 of 4, by jaZz_KCS
I just checked and although the readme files from the 1.3.10.0_x86 driver do not mention Win98 anymore, it's just a neglect, and they indeed do work with Windows 98
