Reply 30420 of 60060, by FAMICOMASTER
Oo, I like that keyboard. What's the difference between a ProDesigner II and a normal ET4000? Would that video BIOS work with a standard ET4000? I quite like those colors.
If anything, those crappy little Herculese clone cards are good for components. The parallel and MDA connectors can be re-purposed, the brackets will fit onto many I/O cards, and can be used as brackets for other connectors. Oh, and if you're a penny-pincher like me, they're a great source of oscillators, logic chips, EPROMs (Looks like yours has a 2764), and 4164 DRAMs. All kinds of goodies from these worthless little things, use them to repair EGA cards and upgrade the RAM of XTs!
Reply 30421 of 60060, by HanJammer
Yup 😁 It doesn't get much more vaporwave than that 😉
It has excellent build quality, but I doubt it differs from other ET4000AX cards... it has some dip switches (I'm not sure what's their purpose - my 3 other ET4000AX card doesn't have them), and that's about it.
ProDesigner card were pretty early ET4000AX cards (this is ProDesigner II, original ProDesigner was a full size card, there was also ProDesigner E) and ET4000 was faster than anything else back then, I guess that's why they called them "Pro".
I will dump the EPROMs tomorrow, so you can check if it works.
Well, I think they are worth more as a whole working card (I paid ~5USD for it)... I have lots of loose TTL chips, oscillators, DRAMs and rest I can buy or source from broken cards... no reason for ruining a working card even if it's crappy...
Reply 30422 of 60060, by JonathonWyble
Warlord wrote:
JonathonWyble wrote:
On Saturday I was at someone's house when I found this interesting little calculator in their basement. […]
It seems to be a calculator from the tech company Sharp.
When I told the guys about this thing, I asked if I could take it, and they just said "Sure, take it. We don't use it anyway."
wait what? I don't know if I should feel old for using a calculator or i'm being trolled here.
Huh? Nah, I don't think you'd have to feel trolled for using an older calculator. I mean, this calculator probably isn't old, like, from the 90's, it's probably from the early 2000s or so. I do have a couple newer calculators as well, but I just found this one and the previous holders told me I could keep it.
1998 Pentium II build
Reply 30423 of 60060, by Zero_sugar
7800GS completes my late-era AGP cards.
Reply 30424 of 60060, by Anonymous Coward
HanJammer wrote:
Saved from crusher...
Keyboard is XT/AT unfortunatelly it misses one of the button caps (anybody recognizes what microswitch it is?) and the spiral cable is stretched a bit.
Keyboard is made by a company called "Maxiswitch". I had this one on my first 486 PC. I don't know what kind of switches it uses, but I always considered it pretty decent. Still have it too.
Reply 30425 of 60060, by cyclone3d
Zero_sugar wrote:
https://imgur.com/I0YJJiy.jpg […]
Oh nice,
What all late-era AGP cards do you have?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30426 of 60060, by Grzyb
ProDesigner II also comes in full-length variant, see the attachment.
Yours looks like ProDesigner IIs
Anyway, that translation ROM is likely to match - http://www.vcfed.org/forum/showthread.php?569 … Translation-ROM
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 30427 of 60060, by HanJammer
Grzyb wrote:
ProDesigner II also comes in full-length variant, see the attachment. Yours looks like ProDesigner IIs […]
Yes that's IIs - I've seen this translation ROM yesterday when googling for information about the card - I will try it for sure! Thanks.
Reply 30428 of 60060, by Thermalwrong
HanJammer wrote:
Grzyb wrote:
ProDesigner II also comes in full-length variant, see the attachment. Yours looks like ProDesigner IIs Anyway, that translation […]
I've got the same card (the IIs), I'll have to give this a try too 😁
Reply 30429 of 60060, by HanJammer
At the second look - Grzyb was wrong - it's not ProDesigner IIs but ProDesigner II. Although it does look like "s" variant it doesn't have 's' letter added on the PCB, both stickers on EPROMs state it's "II" not "IIs" and also video BIOS message states it's "II" (IIs' BIOS message should look like this: https://www.youtube.com/watch?v=B9aZgRk3k-U
Reply 30430 of 60060, by Grzyb
Maybe.
Nevertheless, it does have the most important feature of IIs - socketed RAMDAC, so it can be replaced with that hi-color Sierra thing.
Reply 30431 of 60060, by ShovelKnight
Bought a used Cooler Master Elite 360 which is I believe the smallest case for full ATX motherboards.
Reply 30432 of 60060, by SpectriaForce
dionb wrote:
For nostalgia's sake I have an Aztech MR-2800 in my ultimate P3 build (Tualatin 1400S, DDR, SiS635T chipset).
Which motherboard do you use for your ultimate P3 system?
Reply 30433 of 60060, by SpectriaForce
wiretap wrote:
Dell Dimension 8250 Motherboard (socket 478 / RAMBUS-1066 support) https://imgur.com/eaOKkPjh.jpg […]
Does that board fit inside a mATX case and is it compatible with a regular ATX PSU?
Reply 30434 of 60060, by FAMICOMASTER
I've seen those in Optiplex machines. They fit in normal ATX cases, but I'm not sure if they need a special power supply. The connector is the standard 20 pin with the 12 volt connector, so I don't think it's anything special.
The front panel connectors and buttons and the like are non-standard, iirc, so it's useless without those.
Reply 30435 of 60060, by Vynix
IIRC Dell used a non-standard ATX connector pinout, so if you plugged à regular ATX PSU onto a Dell mobo, you could very well burn the PSU or the mobo! (however I ain't sure if they still use that non-standard pinout these days...)
Edit: http://www.informit.com/articles/article.aspx?p=339053
Reply 30436 of 60060, by SpectriaForce
Somewhere during the early 2000's they changed that. The question is when and whether that S478 board is compatible with a regular ATX PSU, because proprietary Dell PSU's are hard to find and expensive if you do find them. You can however mod a regular ATX PSU for Dell proprietary boards (been there, done that), but it's a bit of a hack job.
Reply 30437 of 60060, by MMaximus
HanJammer wrote:
And this ProDesigner II card <3 - I loved it's BIOS intro: https://youtu.be/gBggJP7L1dI - gotta hoard all ET4000 cards I can find before Atari ST guys will ruin them all ;]
Nice. I have an Orchid Designer 800 that does a similar thing on BIOS startup.
What do Atari ST guys want ET4000 cards for?
Hard Disk Sounds
Reply 30438 of 60060, by wiretap
Normal ATX case, normal ATX power supply, no special pinout on the ATX connector.
My Github
Circuit Board Repair Manuals
Reply 30439 of 60060, by HanJammer
ST and even STe has pitiful resolution and offers very limited amount of colours which can be displayed on the screen at the same time.
ET4000AX / W32i or ATI Mach 32/64 cards supposedly cures this problems. Why these particular cards? Perhaps card requires some mods (GAL chips? EPROM?) that are possible only in Tseng or ATI cards, or maybe it's because of driver availability...
Edit: https://translate.google.com/translate?sl=aut … 2Fpanther2.html
