First post, by kalm_traveler
- Member
Hi guys - I've been away for a few months but am back to fiddling around with my retro parts pile now and have been trying to decide where to put my efforts...
My intention with a retro rig stemmed initially from wanting to play Zork Nemesis and Zork Grand Inquisitor on more appropriate hardware because their in-game turning speed seems tied to CPU clock speed, and anything over maybe 1.4ghz is basically unplayable because even with the in-game turn speed setting set to slowest you'll still turbo-spin. These games were released I believe in 1995 and 1997 so obviously something more in the 450mhz range was expected.
Anyway, I figured that it would be fun to build something with core parts from around when I built my first all-new rig in late 2000, sort of "best PC I could have built without being constrained to a teenage summer job budget", then expanded a bit to wanting to build it powerful enough to be able to play early 2000's games that I missed out on but that don't really run (or run well) on Windows 10 and modern hardware.
So my question for your input is basically.... based on the parts I have laying around now what would make the most sense to focus on using given that I can downclock everything to run those Zork games:
CPUs:
PIII 1ghz, 1.13ghz, pair of 1.4ghz (all Tualatin)
Core 2 Extreme x6800 (dual core LGA775)
MBs:
Asus TUSL2-C (rear USB ports are dead - they read too low of voltage and do not work even with a powered hub, also some resistors are sheared off so the PLED header doesn't work. I could always pick up another board that hopefully works 100%)
Tyan Tiger S2507T dual socket370 (everything seems to work, but I need mega +5v, Corsair HX1200 doesn't seem adequate so I have an Enermax EG701P-VF with 45A on +5v and 36A on +3.3v to recap that should keep it stable)
ASRock 4CoreDual-SATA2 (sometimes doesn't POST - have to reboot a few times but if it POSTs runs fine, only recognizes 3gb of 4g installed DDR2, supposedly should only see 2gb)
graphics cards:
Nvidia Quadro 4000 SDI AGP
Nvidia Quadro 2 Pro
Nvidia Geforce 2 Ultra (yes I know it's basically the same as the Q2P)
sound cards:
SB Live Audigy 2 ZS
Aureal Vortex 2
OS choices: Windows 2000 Pro, Windows ME, Windows 98SE... guess I could pick up a copy of Xp Pro if need be (I think all the games I have will run on any of them)
Anyway - again given that I'm just wanting max flexibility which platform and OS/OSes would you guys recommend? Currently the case has the LGA775 setup in there but last I left off was Win98SE failing to install since there's no way to provide it with the ASRock built-in SATA2 drivers that I am aware of.
*EDIT* I should add that I have 2 very capable modern PCs (overkill rig is i9 7960x cpu, 64gb DDR4, two Titan RTX graphics cards; other desktop is an i7 7700, 16gb DDR4, Geforce GTX 1070) so if emulation of something would be better for some era I can do that but want to make use of a retro PC as much as possible.
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 13900ks, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
