First post, by Warlord
- l33t
Looking for advice, on good eeprom programmer. For retro BIOS chips 😕
What have you found so far?
That's the good one in my experience, you can even test SRAM cache chips with it.
I've programmed chips from a 1993 laptop in it and the software is pretty good.
Since the seller is xgecu, that should not be a fake 😀
Second that. 'It just works' for just about any EEPROM (or other flashable device) you throw at it. Bought one a few months ago and tested it against a pile of EEPROMs I still had from the 90s and 00s. Only ones I couldn't read or write were some relabeled EEPROMs from PC Chips boards. Probably could have done those too if I'd been able to figure out what they really were.
yeah, get that one ^^
I got a used Genius G540 off ebay because it was a little bit cheaper, and I regret my decision because it is such a hassle to set up... the manufacturers website being offline by now doesn't help either... but oh well, at least I got one of those cheap EPROM erasers with it ^^
+1 get the TL866 II
I have one of those (TL866) and it has worked very well for me, definitely recommended.
I've got both the G540 and the TL866 and I'm glad about it. 😀
Just wished they had a dedicated PSU each (I'm using USB 3 ports as a workaround; they provide more power).
The TL866MK2 lost support for writing 21v/24v/25v EPROMs or so I heards..
PS: Some private person fixed the G540 software's Engrish, by the way.
