First post, by Robhalfordfan
Hi all
I ordered these for a build and didn't noticed till I start led putting it together and wonder if these would be safe and OK to use together and if not, which is better to use
2 of them are one set of timing and voltage, while the other 2 are different set of timing and voltage
Reply 2 of 53, by Robhalfordfan
OK does the voltages matter and read different things on net and got confused and if i have to choose one set, which is better and i can see if can find another set with same timing and voltage etc
Reply 3 of 53, by Horun
The ram with 1.8v is what I would use, that is the standard voltage of DDR2. The ones that require 2.1v to run at 800 would be inferior chips IMHO even though their CAS is lower because they require higher voltage to attain the 800mhz and CAS4 over 800Mhz and CAS5 of the ones at 1.8v. Sorta like overclocked by being over voltaged. The 2.1v may run very stable at 1.8v with 5-5-5-16 timing as dr_st stated but only a good mem test would tell. I would not mix them on same board.
Reply 4 of 53, by Robhalfordfan
ok safer and better to use the lower voltage ones rather the lower cas ones
Reply 5 of 53, by red-ray
No, I suspect the extra voltage is just to get the lower timings and the DIMM SPD contains EPP data. To sensibly comment I would need to see the DIMM SPD data.
I had a look and found as below in the SIV save files I have. If yours are similar I expect running all four @ 1.8 volts + 400 MHz will be fine.
[SPD Summary] <- SIV32X - System Information Viewer V5.43 Beta-04 FATARSE2::argh
SIV32X - BIOSTAR A780X-A2 SPD Summary for 2 DIMMs took 0.000 seconds on \\FATARSE2 - Windows 2K x32 Professional V5.00 Build 2195 Service Pack 4
SMBus Total for 2 DIMMs 2GB Banks Manufacturer (DRAM) Part Number Serial # [_]Speed [Y]Suppress Same
0_52 DDR2 SDRAM UDIMM 1GB 1 1Gb Corsair CM2X1024-8500C5D 0000-0000 Clock tCL tRCD tRP tRAS tRC |G|CRC Volts
PC2-6400 (400MHz) JEDEC 1 270.3MHz 4 4 4 13 16 Ranks 1 1.80
2 400.0MHz 5 5 5 18 23
EPP FP 2 533.3MHz 5 4 4 14 21 2T 2.10
0_53 DDR2 SDRAM UDIMM 1GB 1 1Gb ... ... ... ...
[ OK ] [ Copy] [Windows] [Machine] [ DIMMs] [Sensors] [Status] [USB Bus] [ SPD ] [Volumes] [SMB Bus] [PCI Bus] [ALL Dev]
[SPD Summary] <- SIV32X - System Information Viewer V5.43 Beta-04 AMD-64-3500::Dick
SIV32X - ELITEGROUP NFORCE6M-A SPD Summary for 4 DIMMs took 0.000 seconds on \\AMD-64-3500 - Windows XP Professional V5.01 Build 2600 Service Pack 3
SMBus Total for 4 DIMMs 4GB Banks Manufacturer (DRAM) Part Number Serial # [_]Speed [Y]Suppress Same
0_50 DDR2 SDRAM UDIMM 1GB 2 512Mb Corsair CM2X1024-6400C5DHX FFFF-FFFF Clock tCL tRCD tRP tRAS tRC |G|CRC Volts
PC2-6400 (400MHz) JEDEC 1 270.3MHz 4 4 4 13 15 Ranks 2 1.80
2 400.0MHz 5 5 5 18 22
0_51 DDR2 SDRAM UDIMM 1GB 2 512Mb ... ... ... ...
0_52 DDR2 SDRAM UDIMM 1GB 1 1Gb Micron 8HTF12864AY-800E1 E81A-B097 Clock tCL tRCD tRP tRAS tRC |G|CRC Volts
PC2-6400 (400MHz) JEDEC 1 266.7MHz 4 4 4 12 16 Ranks 1 1.80
2 333.3MHz 5 5 5 15 20
3 400.0MHz 6 6 6 18 24
0_53 DDR2 SDRAM UDIMM 1GB 1 1Gb ... ... E81A-B096 ...
Reply 6 of 53, by Robhalfordfan
red-ray wrote:
No, I suspect the extra voltage is just to get the lower timings and the DIMM SPD contains EPP data. To sensibly comment I would […]
how do i that
Reply 7 of 53, by red-ray
Robhalfordfan wrote:
how do i that
It depends on which OS the system is running, if it's running Windows NT, 2K, XP or later then you could download the SIV32L.zip that's attached to SIV support for 386/486/586 class + Alpha CPUs and 3dfx + S3 + SiS + Matrox + XGI + old ATI + NVidia GPUs - Testing Help, extract the files, run SIV32L.exe then press the [ SPD ] button and post a screen shot similar to as below. You could either do this twice, once for each pair of DIMMs or assume all four will be OK @ 1.8 volts and install all four.
file.php?id=70852
If the system is running Windows 9X then you will need to use such as CPUZ or HWiNFO.
Reply 8 of 53, by agent_x007
800MHz CL5.5.5.18 at 1,8V USUALLY means 800MHz CL4.4.4.12 at ~2,1V. Usually, ie. memory should OC to that (OC'ing margins for DDR2).
Since Intel boards don't support EPP [nVidia thing only], you don't have to worry about wrong voltage : Board will always use 1,8V for Auto setting from jEDEC profile (unless BIOS is bugged).
2,1V have to be set manually in BIOS by You (and the same goes for timings).
You shouldn't have issues pairing those together.
Keep in mind, using 4 sticks usually limits OC, and 2,1V (if Airflow isn't good enough) voltage may cause excessive heating on two middle sticks.
Reply 9 of 53, by red-ray
This statement is incorrect, I used to have an ASUS P5Q PRO Turbo with an Intel chipset and EPP DIMMs and below is another example of one from a SIV save file I have. I don't know how the ASUS P5Q Deluxe was setup, but the P5Q PRO Turbo specifies EPP in the QVL and I did not setup the timings manually.
Further as neither the motherboard or CPU has been specified I can't see how you can assume it is Intel.
file.php?id=70856
Notice how the current memory timings are the EPP timings.
file.php?id=70855
Reply 10 of 53, by agent_x007
Background : EPP = Enhanced Performance Profiles
And it's nVidia's version of XMP (before XMP was a thing), it became a thing in later DDR2 memory.
"EPP" is a PROFILE in SPD, and I meant it as such.
Memory support is beyond that, since ALL RAM must have a basic JEDEC profile regardless of EPP, and JEDEC MUST work.
QVL list doesn't mean you have "XMP" or "EPP" option in BIOS to preset everything for you.
It only shows what memory was tested with motherboard and if it worked.
So, two questions :
1) Do you have a "EPP Enable" option in BIOS or did you have to set everything manually (based on values from EPP profile) ?
^Here's example from DDR3 nVidia board.
2) Which profile will BIOS use when there are two mixed EPP enabled memory sets installed ?
^Here's difficult question I don't have an answer to (I never tried it myself 😉)
Reply 11 of 53, by red-ray
agent_x007 wrote:
Background : EPP is nVidia's version of XMP (before XMP was a thing). QVL list doesn't mean you have "XMP" or "EPP" option in BI […]
Background : EPP is nVidia's version of XMP (before XMP was a thing). QVL list doesn't mean you have "XMP" or "EPP" option in BIOS to check for memory to work. It only shows what memory was tested with motherboard.
So, two questions :
1) Do you have a "EPP Enable" option in BIOS or did you have to set everything manually ?
Incorrect again, EPP is DDR2, XMP 1.n DDR3 and XMP 2.n DDR4.
So, two questions :
1) Given I specified "I used to have an ASUS P5Q PRO Turbo" how do you expect me to check what it's BIOS setting are?
2) How do you know which motherboard/chipset and CPU are being used?
Reply 12 of 53, by agent_x007
What do you mean "incorrect" ?
EPP was predesessor of XMP, it did for DDR2 what XMP does for DDR3.
Hence I wrote EPP was earlier version of XMP.
1) You don't remember what you did to set memory up on Your board ?
OK, but you can't blame me for not knowing it (I'm not in Your head).
2) Why do I have to know which is used ?
Most popular ones are Intel and VIA, nForce is minority.
Intel and VIA don't support EPP, so you have to manually set everything in BIOS.
I wrote about nV earlier.
Again EPP is a PROFILE, NOT a memory type or model.
Reply 13 of 53, by red-ray
1) You don't remember what you did to set memory up on Your board ? OK, but you can't blame me for not knowing it (I'm not in Your head).
When you don't know what a word means then I suggest you Google for it's meaning and from doing that you should find https://dictionary.cambridge.org/dictionary/e … glish/incorrect
I further suggest you should read what I specified as you clearly failed to do this given what I quoted above.
Telling me "EPP is a PROFILE" is comparable to telling chickens how to lay eggs.
I don't see how any of what you has said will help Robhalfordfan to fully understand what is possible and I am at a loss as to why you posted as you did.
Robhalfordfan: I suggest you ignore most of what agent_x007 posted as he is talking in general terms and has no way to know which motherboard/chipset and CPU you have.
Reply 14 of 53, by agent_x007
I think you are overreacting if you say OP should ignore all I wrote just because you don't agree wih something I wrote. Also I read what you wrote, and I wanted to know if your board had "EPP Enable" option from example provided on earlier screenshot.
PS. What OP needed to know is in my first post in this topic.
Reply 15 of 53, by red-ray
No, OP needs to provide details of the SPD so a decision can be made based on appropriate data rather than relying on your guesses being correct.
I also feel you should do as I did and provide screen shots to justify your statements.
Reply 16 of 53, by agent_x007
You want me to buy OPs memory, OC it as I wrote in my post and post screenshots ?
Because I'm pretty sure every other screenshot I post will just get "shot down" as "using not correct memory".
Reply 17 of 53, by red-ray
As to how you justify your statements is up to you, all I specified is that I feel you need to justify them.
Further given OP specified ok safer and better to use the lower voltage ones rather the lower cas ones I suspect he does not wish to overclock his DIMMs.
Reply 18 of 53, by dr_st
I have an ASUS P5Q PRO (Intel P45) and DDR2 RAM which has an EPP profile for 1066MHz (see attached image). I can confirm that when RAM frequency is set to DDR2-1066 in the BIOS (this is determined using one of possible FSB:DRAM dividers), it reads the correct SPD timing values automatically.
Dunno what it would do if there was both an EPP and a JEDEC profile for the same frequency.
Reply 19 of 53, by red-ray
Thank you for this which confirms what I recall used to happen on my ASUS P5Q PRO Turbo before the DIMMs with the EPP profile failed.
As for mixing DIMMs then I expect if will all depend on what the SPD is for them and there will be no general answer.
