First post, by piatd
I'm looking for evidence that the PIII 800 (either E or EB versions) was available for purchase and use by an individual in 1999, either as a component or part of a system/bundle.
Anandtech noted in its December 20, 1999 review that "[l]ike the Athlon 800, the Pentium III 800 will begin shipping sometime early next year (most likely in January)."
To get my bearings, I looked at advertisements for boutique and multinational system builders in the January 2000 issues of popular US PC magazines: PC Gamer, Computer Gaming World, and Maximum PC.
Alienware: PIII 733 (in Area51 system)
Aberdeen: PIII 733 (in system) & Athlon 750 (bundled with Slot A mobos)
Compaq: PIII 700 *snicker* (in Presario 5700T-700 system)
CyberMax: Athlon 750 (in system)
Dell: PIII 733 (in Dimension XPS B733r system)
HyperSonic: PIII 733 (in system)
The Athlon appeared to be available at 750 MHz and the PIII at 733 MHz. This is not definitive, as I don't know when in December these issues hit newsstands, let alone when they were written. Still, if the PIII 800 had been listed here, I could probably conclude that is was available in 1999.
Jumping ahead to 2000, I waybacked (is this a verb yet?) two popular US boutique builders for their fastest processors:
gamepc.com for Jan 22: Athlon: 750 MHz , PIII: 733 MHz
This is especially telling, because gamepc also indicates the availability status of each part: in stock, backorder (1-2 weeks), or out of stock (indefinite).
alienware.com for February 8 Athlon: 800 MHz , PIII: 733 MHz
The PIII 800 is nowhere to be found. What say you?
Reply 1 of 28, by Warlord
seems like a misunderstanding. It wasn't released until dec 20 1999. So there is no reasonable expectation of why you could find anyone having one in 1999 unless they got it as a Christmas present or something. Seems insane to me. But there is plenty of evidence that Anand Lal Shimpi had them in his hands and tested them pre launch. Which is fairly normal for hardware review.
I don't see why it matters.
Reply 2 of 28, by cyclone3d
According to this page, it was pushed from end of 1999 to 1st quarter of 2000:
https://www.theregister.co.uk/1999/11/17/pent … rought_forward/
Not even listed in the Intel quick processor reference:
https://www.intel.com/pressroom/kits/quickrefyr.htm
All the reviews I am seeing are March 2000 or later.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 28, by jheronimus
It matters for "period-correct" builds. I'm in a similar boat as I'm currently trying to figure out the date when my motherboard hit the market. It's an Intel Advanced/ATX aka Thor. It's significant for me, because it's the original ATX board:
- Intel introduced the ATX standard in July 1995;
- Intel started showing reference boards to system builders in August 1995;
- there is no mention of the board on Intel's site (seems like Intel only put up some info retroactively around 1999). Perhaps, Intel figured that since people couldn't buy the board in retail, they should get support from their system builders;
- a search through newsgroups shows that people first got their hands on Thor in early 1996 at best with systems from Gateway and others.
- the board I got was originally bought in December 1997;
Whether or not you should obsess so much over dates is up to debate, but yeah, "period-correctness" is a real rabbit hole.
MR BIOS catalog
Unicore catalog
Reply 4 of 28, by Munx
I remember that in the Quake3 timedemo thead someone showed off a receipt for a Geforce 256 DDR which they bought right before christmas 1999, even though there are no reviews for one before Y2K.
This made the card eligible for a period-correct 1999 build. Same reason why evidence for this particular CPUs release date is needed.
My builds!
The Underdog - The budget K6
Reply 6 of 28, by Warlord
1999 is the same time period as 2000. I am almost 40 years old I lived then.
Reply 7 of 28, by cyclone3d
If it was available for sale new at that point in time, it would technically be "period correct".
Maybe we need some more categories:
1. Low to just below Mainstream
2. Mainstream
3. Mainstream to High End
4. Pipe dream for almost everybody
Now everybody needs 4 or more builds for every period.
YMF7x4 Guide
Reply 8 of 28, by derSammler
What has the release date of something to do with "period-correct" builds? When you bought a PC back then, did it only contain parts that were all released in the same month of the same year? Of course they were not. A period-correct build is made of parts that were common and available back then. That's it.
Reply 9 of 28, by Warlord
Period correct 1999/2000 is pretty stupid by the way. 75% of the retro computers that you can find fall into 1999-2000 category or at very least the OS, Motherboard, CPU, etc.
Unless your computer is 1999 than you cannot run 98se because that wouldn't be correct since 98se is 1999. 🤣
Reply 11 of 28, by Horun
The EB is coppermine and according to Intel the EB (133mhz version):
Processor Base Frequency 1.00 GHz
Cache 256 KB L2 Cache
Bus Speed 133 MHz
Sockets Supported PPGA370, SECC2
Launch Date: Q1'00.
Which means it could have been as late as March before they released it to market or even slightly later. Looking for an OEM build with it would probably not have happened until summer or fall of 2000. HP released the Vectra VL400 with P3-1Ghz, 133bus after Nov 2000 from what little I can gather.. Here are some links descriping the HP
https://www.hp.com/ecomcat/hpcatalog/specs/P4151T.htm
https://www.cnet.com/products/hp-vectra-vl400 … or-none-series/
Reply 12 of 28, by Big Pink
Some anecdotal evidence: I've been watching listings on eBay for a 99 800EB bound for my super-serious New Year's Eve 1999 $5000 build. Every one I've seen so far has had a year 2000 datecode. They may have been coming out the factory in December, but not in volume.
As a consequence I've adjusted down to a 733 Slot 1, which does seem to have been available by the end of the year on the basis of datecodes as far back as Week 41 1999 (lines up with Wikipedia's listed release date).
cyclone3d wrote:
Maybe we need some more categories: […]
2. Mainstream
Yes, if you want to be immensely retentive about period-accuracy like me, then the 800 is Level 4 and the 733 is Level 3. 🤣
I thought IBM was born with the world
Reply 13 of 28, by jaZz_KCS
Big Pink wrote:
Some anecdotal evidence: I've been watching listings on eBay for a 99 800EB bound for my super-serious New Year's Eve 1999 $5000 […]
2. Mainstream
In my book, given the official dates, I consider my PIII-800 build to be the closest to the edge of the new millennium, CPU-wise. Of course they couldn't deliver a specimen from a batch before 2000 to everyone that wanted one...
40.14 KiB
Reply 14 of 28, by piatd
cyclone3d wrote:
According to this page, it was pushed from end of 1999 to 1st quarter of 2000: https://www.theregister.co.uk/1999/11/17/pent … r […]
Interesting links, thank you. Looking further at The Register, I also found this alleged letter from Intel to its partners, dated January 18, 2000:
"On December 20, 1999 Intel launched the Pentium III processors at 800MHz and 750MHz for desktop PCs. Initial shipments of the 750 MHz processor into the distribution channel (box and tray) are expected to begin in early January '00. Shipments of the 800MHz processor into the distribution channel (box and tray) are expected to begin later in Q1'00."
If true, this is the epitome of a paper launch. I'm assuming that the PIII 800 was a year 2000 part, until evidence shows otherwise. Reviewers possessing chips in 1999 is not evidence (they could be engineering samples, for all we know), nor is a wikipedia article with no pertinent citations.
Reply 15 of 28, by jaZz_KCS
piatd wrote:
Interesting links, thank you. Looking further at The Register, I also found this alleged letter from Intel to its partners, dat […]
"On December 20, 1999 Intel launched the Pentium III processors at 800MHz and 750MHz for desktop PCs. Initial shipments of the 750 MHz processor into the distribution channel (box and tray) are expected to begin in early January '00. Shipments of the 800MHz processor into the distribution channel (box and tray) are expected to begin later in Q1'00." If true, this is the epitome of a paper launch.
I'm writing off the PIII 800 as a year 2000 chip, until evidence shows otherwise. Reviewers possessing chips in 1999 evidence (they could be engineering samples, for all we know), nor is a wikipedia article with no pertinent citations.
I agree, I was solely going by the "official date of release to the public", if that makes any sense... In terms of "when ppl finally got a hold of these", it remains (sadly) a very early 2000 chip.
Reply 16 of 28, by piatd
Why I care:
I'm researching parts that will give me optimal performance in games during a given calendar year. For the purposes of my project, it is important that individual consumers in a retail market could obtain a given part during this year (i.e. "when ppl finally got a hold of these," as jaZz_KCS said before). I can readily admit that these criteria are arbitrary and may not be helpful to other people.
I can expand on why I've chosen them, if anyone is interested.
Reply 17 of 28, by Warlord
Back then regular consumers on average didn't have the fastest computers of a calendar year. Anyways calculating inflation costs a PIII 800 in march 2000 would of costed around 1,100 US dollars way out of the reach for most normal people.
I can tell you from experience of having lived during this time I was 19-20 years old, Id say something like PIII 600 is high end for the target you want for 1999
But yes it is extremely arbitrary and unnecessary because normally speaking higher FPS, higher details settings = optimal gaming experience.
Reply 18 of 28, by maxtherabbit
konc wrote:
I always thought "period-correctness" means more "mainstream during that period" than "elite latest model but could be bought if you're a millionaire"
I feel the opposite of that
period correct to me simply means that the components existed at that moment in time
Reply 19 of 28, by Warlord
I could build a computer with parts that were of the same year that crysis came out and it would run like shit. It would be period correct though. 🤣
