…Show last 471 lines
61      FindMoves HumanColor, WinningLength, FALSE
62      IF NOT FoundMoves THEN
63         FOR TriggerLength = WinningLength TO 0 STEP -1
64            FindMoves ComputerColor, TriggerLength, FALSE
65            IF FoundMoves THEN EXIT FOR
66         NEXT TriggerLength
67
68         IF NOT FoundMoves THEN
69            FOR TriggerLength = WinningLength TO 0 STEP -1
70               FindMoves HumanColor, TriggerLength, TRUE
71               IF FoundMoves THEN EXIT FOR
72            NEXT TriggerLength
73         END IF
74      END IF
75   END IF
76
77   IF FoundMoves THEN
78      DO
79         Column = INT(RND * (LastColumn + 1)) + FirstColumn
80         IF MovesFound(Column) THEN
81            DropDisk Column, CurrentPlayer
82            EXIT DO
83         END IF
84      LOOP
85   END IF
86END SUB
87
88FUNCTION CountDisks (StartColumn, StartRow, ColorO, XDirection, YDirection)
89DIM CheckCount
90DIM Column
91DIM DiskCount
92DIM Row
93
94   Column = StartColumn
95   CheckCount = 0
96   DiskCount = 0
97   Row = StartRow
98   DO WHILE CheckCount < WinningLength
99      SELECT CASE Disks(Column, Row, DCNone, FALSE)
100         CASE ColorO
101            DiskCount = DiskCount + 1
102         CASE NOT DCNone
103            EXIT DO
104      END SELECT
105
106      Column = Column + XDirection
107      Row = Row + YDirection
108      CheckCount = CheckCount + 1
109   LOOP
110
111   CountDisks = DiskCount
112END FUNCTION
113
114FUNCTION Disks (Column, Row, NewDisk, ResetDisks)
115DIM Disk
116
117   Disk = DCOutsideField
118
119   IF ResetDisks THEN
120      ERASE CurrentDisks
121      Disk = DCNone
122
123      FOR Column = FirstColumn TO LastColumn
124         FOR Row = FirstRow TO LastRow
125            CurrentDisks(Column, Row) = DCNone
126         NEXT Row
127      NEXT Column
128   ELSE
129      IF Column >= FirstColumn AND Column <= LastColumn THEN
130         IF Row >= FirstRow AND Row <= LastRow THEN
131            IF NOT NewDisk = DCNone THEN CurrentDisks(Column, Row) = NewDisk
132            Disk = CurrentDisks(Column, Row)
133         END IF
134      END IF
135   END IF
136
137   Disks = Disk
138END FUNCTION
139
140SUB DisplayHelp
141   CLS : COLOR 15
142   PRINT
143   PRINT SPC(3); "Connect Four - Help"
144   PRINT
145   PRINT SPC(3); "Keys:"
146   PRINT SPC(3); "F1  = This help."
147   PRINT SPC(3); "F2  = No computer player."
148   PRINT SPC(3); "F3  = Computer plays as red."
149   PRINT SPC(3); "F4  = Computer plays as yellow."
150   PRINT SPC(3); "A   = Restart game."
151   PRINT SPC(3); "Q   = Quit game."
152   PRINT SPC(3); "R   = Red plays first."
153   PRINT SPC(3); "Y   = Yellow plays first."
154   PRINT SPC(3); "1-7 = Drop disk into column."
155   DO WHILE INKEY$ = "": LOOP
156END SUB
157
158SUB DrawDisk (Column, Row, ColorO)
159   LINE (Column * SlotSize, Row * SlotSize)-STEP(SlotSize, SlotSize), 0, B
160   CIRCLE ((Column + .5) * SlotSize, (Row + .5) * SlotSize), SlotSize / 2.5, 0
161   SELECT CASE ColorO
162      CASE DCNone
163         COLOR 11
164      CASE DCRed
165         COLOR 12
166      CASE DCYellow
167         COLOR 14
168   END SELECT
169   PAINT ((Column + .5) * SlotSize, (Row + .5) * SlotSize), , 0
170END SUB
171
172SUB DrawDisks
173DIM Column
174DIM Row
175
176   CLS
177   LINE (-1, -1)-(((ABS(LastColumn - FirstColumn) + 1) * SlotSize) + 1, ((ABS(LastRow - FirstRow) + 1) * SlotSize) + 1), 7, BF
178   LINE (0, 0)-((ABS(LastColumn - FirstColumn) + 1) * SlotSize, (ABS(LastRow - FirstRow) + 1) * SlotSize), 1, BF
179   FOR Column = FirstColumn TO LastColumn
180      FOR Row = FirstRow TO LastRow
181         DrawDisk Column, Row, Disks(Column, Row, DCNone, FALSE)
182      NEXT Row
183   NEXT Column
184END SUB
185
186SUB DropDisk (Column, ColorO)
187DIM DelayStart!
188DIM Disk
189DIM KeyStroke$
190DIM Row
191
192   IF Disks(Column, FirstRow, DCNone, FALSE) = DCNone THEN
193      Row = FirstRow
194      DO
195         DrawDisk Column, Row, ColorO
196
197         IF Row = LastRow THEN
198            EXIT DO
199         ELSE
200            IF NOT Disks(Column, Row + 1, DCNone, FALSE) = DCNone THEN EXIT DO
201         END IF
202
203         DelayStart! = TIMER
204         DO WHILE TIMER < DelayStart! + DropDelay!
205            IF TIMER < DelayStart! THEN DelayStart! = TIMER
206         LOOP
207
208         DrawDisk Column, Row, DCNone
209         Row = Row + 1
210         KeyStroke$ = INKEY$
211      LOOP
212
213      Disk = Disks(Column, Row, ColorO, FALSE)
214
215      SELECT CASE CurrentPlayer
216         CASE DCRed
217            CurrentPlayer = DCYellow
218         CASE DCYellow
219            CurrentPlayer = DCRed
220      END SELECT
221
222   END IF
223   SelectedColumn = NoColumn
224END SUB
225
226SUB FindMoves (ColorO, TriggerLength, AllowHelpingOpponent)
227DIM Column
228DIM CheckColumn
229DIM CheckCount
230DIM CheckRow
231DIM DiskCount
232DIM FoundMove
233DIM Row
234DIM XDirection
235DIM YDirection
236
237   ERASE MovesFound
238
239   FOR Column = FirstColumn TO LastColumn
240      FOR Row = FirstRow TO LastRow
241         FOR XDirection = -1 TO 1
242            FOR YDirection = -1 TO 1
243               IF NOT (XDirection = 0 AND YDirection = 0) THEN
244                  CheckColumn = Column
245                  CheckRow = Row
246                  CheckCount = 0
247                  DiskCount = 0
248                  FoundMove = NoColumn
249
250                  DO UNTIL CheckCount = TriggerLength
251                     SELECT CASE Disks(CheckColumn, CheckRow, DCNone, FALSE)
252                        CASE ColorO
253                           DiskCount = DiskCount + 1
254                        CASE DCNone
255                           SELECT CASE Disks(CheckColumn, CheckRow + 1, DCNone, FALSE)
256                              CASE DCRed, DCYellow, DCOutsideField
257                                 FoundMove = CheckColumn
258                           END SELECT
259                        CASE ELSE
260                           EXIT DO
261                     END SELECT
262
263                     CheckColumn = CheckColumn + XDirection
264                     CheckRow = CheckRow + YDirection
265                     CheckCount = CheckCount + 1
266                  LOOP
267
268                  IF DiskCount = TriggerLength - 1 THEN
269                     IF NOT FoundMove = NoColumn THEN
270                        IF AllowHelpingOpponent THEN
271                           MovesFound(FoundMove) = TRUE
272                        ELSE
273                           IF NOT MoveHelpsOpponent(HumanColor, FoundMove) THEN MovesFound(FoundMove) = TRUE
274                       END IF
275                    END IF
276                 END IF
277              END IF
278           NEXT YDirection
279        NEXT XDirection
280      NEXT Row
281   NEXT Column
282END SUB
283
284FUNCTION FoundMoves
285DIM Column
286DIM Found
287
288   Found = FALSE
289   FOR Column = FirstColumn TO LastColumn
290      IF MovesFound(Column) THEN
291         Found = TRUE
292         EXIT FOR
293      END IF
294   NEXT Column
295
296   FoundMoves = Found
297END FUNCTION
298
299FUNCTION GameDone
300DIM Column
301DIM Done
302
303   Done = TRUE
304   FOR Column = FirstColumn TO LastColumn
305      IF Disks(Column, FirstRow, DCNone, FALSE) = DCNone THEN
306         Done = FALSE
307         EXIT FOR
308      END IF
309   NEXT Column
310
311   GameDone = Done
312END FUNCTION
313
314FUNCTION GetGameState
315DIM GameState
316
317   SELECT CASE WinningPlayer
318      CASE DCNone
319         IF GameDone THEN
320            GameState = GSTied
321         ELSE
322            SELECT CASE CurrentPlayer
323               CASE DCNone
324                  GameState = GSNeitherPlaying
325               CASE DCRed
326                  GameState = GSRedPlaying
327               CASE DCYellow
328                  GameState = GSYellowPlaying
329            END SELECT
330         END IF
331      CASE DCRed
332        GameState = GSRedWon
333      CASE DCYellow
334        GameState = GSYellowWon
335   END SELECT
336
337   GetGameState = GameState
338END FUNCTION
339
340SUB GreyOutDisks
341DIM Column
342DIM Row
343
344   FOR Column = FirstColumn TO LastColumn
345      FOR Row = FirstRow TO LastRow
346         CIRCLE ((Column + .5) * SlotSize, (Row + .5) * SlotSize), SlotSize / 2.5, 0
347         SELECT CASE Disks(Column, Row, DCNone, FALSE)
348            CASE DCRed
349               COLOR 4
350            CASE DCYellow
351               COLOR 6
352            CASE ELSE
353               COLOR 8
354         END SELECT
355         PAINT ((Column + .5) * SlotSize, (Row + .5) * SlotSize), , 0
356      NEXT Row
357   NEXT Column
358END SUB
359
360SUB InitializeGame
361STATIC CurrentFirstColor
362
363   RANDOMIZE TIMER
364   CurrentPlayer = DCNone
365   tmp = Disks(FirstColumn, FirstRow, DCNone, TRUE)
366   DrawDisks
367   GreyOutDisks
368   SelectedColumn = NoColumn
369
370   COLOR 15: LOCATE 3, 3: PRINT "Connect Four, by: Peter Swinkels - press any key."
371   DO WHILE INKEY$ = "": LOOP
372   DrawDisks
373   CurrentPlayer = FirstColor
374END SUB
375
376FUNCTION MoveHelpsOpponent (OpponentColor, Column)
377DIM HelpsOpponent
378DIM Row
379DIM XDirection
380DIM YDirection
381
382   HelpsOpponent = FALSE
383   Row = 0
384   DO UNTIL (Row = LastRow) OR (NOT Disks(Column, Row + 1, DCNone, FALSE) = DCNone) OR (NOT InterfaceWindow.Visible)
385      Row = Row + 1
386   LOOP
387
388   IF Row > FirstRow THEN
389      Row = Row - 1
390
391      FOR XDirection = -1 TO 1
392         FOR YDirection = -1 TO 1
393            IF NOT (XDirection = 0 AND YDirection = 0) THEN
394               IF CountDisks(Column, Row, OpponentColor, XDirection, YDirection) = WinningLength - 1 THEN
395                  HelpsOpponent = TRUE
396               END IF
397            END IF
398         NEXT YDirection
399      NEXT XDirection
400   END IF
401
402   MoveHelpsOpponent = HelpsOpponent
403END FUNCTION
404
405SUB PlayGame
406DIM KeyStroke$
407
408   ComputerColor = DCYellow
409   FirstColor = DCRed
410   HumanColor = DCRed
411
412   InitializeGame
413
414   DO
415      COLOR 15
416      LOCATE 3, 3: PRINT "Connect Four - F1 = Help"
417      LOCATE 5, 1: PRINT SPACE$(80)
418      LOCATE 5, 20: PRINT StateText
419
420      SELECT CASE GetGameState
421         CASE GSRedPlaying, GSYellowPlaying
422            IF NOT CurrentPlayer = ComputerColor THEN
423            DO
424               KeyStroke$ = INKEY$
425            LOOP WHILE KeyStroke$ = ""
426            SELECT CASE KeyStroke$
427               CASE "A", "a"
428                  InitializeGame
429               CASE "Q", "q"
430                  SCREEN 0: WIDTH 80, 25: COLOR 7, 0: CLS
431                  END
432               CASE "R", "r"
433                  FirstColor = DCRed
434                  InitializeGame
435               CASE "Y", "y"
436                  FirstColor = DCYellow
437
438                  InitializeGame
439               CASE CHR$(0) + ";"
440                  DisplayHelp
441                  DrawDisks
442               CASE CHR$(0) + "<"
443                  ComputerColor = DCNone
444
445                  InitializeGame
446               CASE CHR$(0) + "="
447                  ComputerColor = DCRed
448                  HumanColor = DCYellow
449
450                  InitializeGame
451               CASE CHR$(0) + ">"
452                  ComputerColor = DCYellow
453                  HumanColor = DCRed
454
455                  InitializeGame
456               CASE "1" TO "7"
457                  IF NOT GetGameState = GSNeitherPlaying THEN SelectedColumn = VAL(KeyStroke$) - 1
458            END SELECT
459         END IF
460      END SELECT
461
462      SELECT CASE GetGameState
463         CASE GSRedPlaying, GSYellowPlaying
464            IF ComputerColor = DCNone THEN
465               IF NOT SelectedColumn = NoColumn THEN DropDisk SelectedColumn, CurrentPlayer
466            ELSE
467               IF CurrentPlayer = ComputerColor THEN
468                  ComputerMakeMove
469               ELSE
470                  IF NOT SelectedColumn = NoColumn THEN DropDisk SelectedColumn, CurrentPlayer
471               END IF
472            END IF
473         CASE GSRedWon, GSYellowWon, GSTied
474            GreyOutDisks
475            DO WHILE INKEY$ = "": LOOP
476            InitializeGame
477      END SELECT
478   LOOP
479END SUB
480
481FUNCTION StateText$
482DIM Text$
483
484   Text$ = ""
485   SELECT CASE GetGameState
486      CASE GSNeitherPlaying
487         Text$ = "Inactive."
488      CASE GSRedPlaying
489         Text$ = "Red's turn."
490      CASE GSYellowPlaying
491         Text$ = "Yellow's turn."
492      CASE GSRedWon
493         Text$ = "Red won."
494      CASE GSYellowWon
495         Text$ = "Yellow won."
496      CASE GSTied
497         Text$ = "Game is tied."
498   END SELECT
499
500   StateText$ = Text$
501END FUNCTION
502
503FUNCTION WinningPlayer
504DIM ColorO
505DIM Column
506DIM Row
507DIM XDirection
508DIM YDirection
509DIM Winner
510
511   Winner = DCNone
512
513   FOR ColorO = DCRed TO DCYellow
514      FOR Column = FirstColumn TO LastColumn
515         FOR Row = FirstRow TO LastRow
516            FOR XDirection = -1 TO 1
517              FOR YDirection = -1 TO 1
518                 IF NOT (XDirection = 0 AND YDirection = 0) THEN
519                    IF CountDisks(Column, Row, ColorO, XDirection, YDirection) = WinningLength THEN
520                       Winner = ColorO
521                    END IF
522                 END IF
523              NEXT YDirection
524            NEXT XDirection
525         NEXT Row
526      NEXT Column
527   NEXT ColorO
528
529   WinningPlayer = Winner
530END FUNCTION
