What’s this chip by my 368 cpu?
First post, by walterg74
Hi all,
I have this generic “pc chips” motherboard with a 386 DX CPU, and noticed it had another processor installed
I thought it was a 387 FPU, and that the blue socket was one of those for “upgrading” to a 486 type CPU, but upon taking the worthless warranty sticker off I see that it says as you can see on the pic “4C87DLC-40”...
So what exactly is this processor?
What would the blue socket be for?
(Although too dark in the pic, the one on the right is the AMD 386 DX-40)
The attachment 458359E3-44D8-495C-BDB1-80795ECFB8BD.jpeg is no longer available
Reply 1 of 20, by Miphee
"General info
The IIT DLC is the mathematical co-processor for 386/486 hybrid processors such as the Cyrix Cx486 DLC/SLC and Texas Instruments TX486DLC."
Reply 2 of 20, by derSammler
It is a 387 FPU. Or rather, a compatible one made to accompany a 486DLC.
Reply 3 of 20, by walterg74
So... should it not really be installed there by the 386DX..?
Reply 4 of 20, by walterg74
Miphee wrote:
"General info
So it does not really belong there..?
Reply 5 of 20, by derSammler
It's compatible, so while it's originally meant for a 486DLC, it will work fine with a 386DX as well.
Reply 6 of 20, by Miphee
It's a working pair.
Reply 7 of 20, by walterg74
Ok cool.
Now I guess I’ll decide which is best to keep, if this setup or a different one I have with a 386SX but also 40Mhz... Motherboard is different though, it’s M396F V2.6 that does not seem to be PC Chips.
Reply 8 of 20, by Anonymous Coward
If it's an M396F it should be PC chips (or one of their alternate names). What's written on the chipset?
Reply 9 of 20, by walterg74
Maybe it’s a rebranded pc chips then, seems to be this same one but a slightly higher version number...
https://www.philscomputerlab.com/forcom-m396f.html
Reply 10 of 20, by Vynix
Personally I'd keep the DX40, the SX is practically crippled by its 16-bit bus.
Reply 11 of 20, by Deksor
Definitely not a PCChips m396f, mine has 4 simm slots and hosts a 386sx class CPU, and there is no LIF socket such as this in it.
You can see here how mine looks like : SARC RC2016A8 chipset on PCChips M396F
Reply 12 of 20, by walterg74
I think they all have the same origin. Mine has a different branding on the chipset (see next post) but still...
Reply 13 of 20, by walterg74
The attachment 7F3D5E38-6E03-480B-9A8A-479FC52475D2.jpeg is no longer available
Reply 14 of 20, by Deksor
Wait you have two mobos ? I thought just had the one in your first post ^^
Well then your 386SX is the same as mine, PCChips is known to rebrand chipsets, they kept doing that up to the pentium 3 era at least. Mine must just have the original chipset not rebranded for some reasons. Knowing which chipset they use can be useful for many reasons : troubleshooting (if you know what they used, then it's easier to find the pinout or the chipset if you have some issues with the mobo), finding better bioses (other mobos might use the same chipset which may have better bioses)
Edit ah well maybe I don't have the original chipset name either.
Reply 15 of 20, by walterg74
Yes, I have two, started asking about the one in the OP, but then questioned which to keep and we started talking about the SX board. Seeing which males more sense to keep and which to sell off
Reply 16 of 20, by Deksor
Well if you want the fastest of the two, the one with the DX is definitely the better choice. You have a DX40 on it which is much faster than the 386SX40 on your other board. Furthermore, your DX has eight simm slots which means that you can easily install 8MB of ram on it whereas you need to find rare 4MB Simms for the 386SX board to reach that amount.
Reply 17 of 20, by walterg74
Yes, true. Also has cache.
Not sure I understand the “4MB simms to get 8MB”. Wouldn’t you with 4 x 2MB ones..?
Reply 19 of 20, by derSammler
2 MB SIMMs do exist, but they are uncommon.
